Brake bleeding sequence
The car is a 2000 Civic Ex with Si rear disc brake conversion.
Until today, I always followed the "start on the farthest wheel from MC and work your way to it" bleeding procedure. Thus, my sequence used to be:
Right Rear -> Left Rear -> Right Front -> Left Front
However, I was told today by a pretty reputable source that that is not the correct procedure, and the right sequence is:
Right Rear -> Left Front -> Left Rear -> Right Front
Could someone confirm this for me?
Thanks.
Thanks.
jus f0 dekarayshunZ
Re: Brake bleeding sequence (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">Who is your "pretty reputable source"? I've never heard of it being done any way except the first method you described.</TD></TR></TABLE>i agree
Re: Brake bleeding sequence (CiRcUiTsi)
the whole point in doing it the first way is because you want to bleed the longest line first and go from longest to shortest.....would be a waist to start with a short line when a long *** line has a ton of air in it
that's what the helms manual tells you to do it: right rear, left front, left rear, and right front. kinda weird but that's honda.
Re: Brake bleeding sequence (dynamo)
you dont always start with the longest line first. i know for a fact that you bleed the left front on a crv first. but thats a crv and u get my point. do what the book tells you to do. helms is a damn good source to get all this info. go with the book.
Re: (stripes777)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stripes777 »</TD></TR><TR><TD CLASS="quote">can someone explain to me why there are brakelines in the back drums, i thought the drums only work with the ebrake. does the ebrake require brake fluid to work?</TD></TR></TABLE>
Wow. Anyways, rear drums are brakes just like rear disks which require brake lines. The e-brake is cable operated and uses no fluid whatsoever.
FuNkDrSpOt
05-10-2008 08:52 AM
eg686
21
04-04-2005 05:07 PM
everlasting1832
02-14-2005 11:24 AM
89dxhunchback
37
01-01-2005 12:07 PM
