Bosch Vs. NGK Plugs
Bosch Vs. NGK Plugs
Ok. The almighty popular question. What do you prefer, Bosch Plugs or NGK Plugs. Sorry guys, I forgot +4 s, but just vote +2 s if your a fan ... but in my world they are the same ! =]
All Motor Mentor
1 Post
Re: Bosch Vs. NGK Plugs (KKVTi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KKVTi »</TD></TR><TR><TD CLASS="quote">NGK or DENSO ONLY for Honda... </TD></TR></TABLE>
YEP...leave the Bosch for the European cars and forget about all the extra ground straps (+4) they do not enhance performance, they shroud the spark to the intake charge.
All Motor Mentor
1 Post
Re: Bosch Vs. NGK Plugs (Foxcow)
it means that they block some of the spark to the incoming intake charge reducing the plugs efficiency to ignite the mixture. I'm sure you've heard of people "unshrouding the valves" when porting a head...all they do there is remove some material from the head, around the valve to allow the intake charge to flow better (more efficiently) into the combustion chamber.
1 Post
Re: (Art In Motion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Art In Motion »</TD></TR><TR><TD CLASS="quote">OEM</TD></TR></TABLE>
Re: (Art In Motion)
You guys crack me up....
I have some Bosh Platinum +4's installed. They're better than the NGKs that have been in there since day one I'm sure because they're fresher, but I want to switch over to some Denso Iridiums ASAP... won't really matter though, to be real nobody will notice a difference.
* B A N N E D *
1 Post
Re: Bosch Vs. NGK Plugs (jaycapz)
NGK. When I bought V Power, the old ones that came with my car (used) were the same damn part number. I say get the Iridium ones, cause they'll last longer, and there not that expensive for a part that'll last 100,000 miles, 30$ aint bad. Plus all its pro's and ****, I liked em. Help with a smooth idle. Stick with what Honda says. NGK V-Power or for a few more bucks, theres no reason not to get the Iridium.
The 4 tipped plugs are a waste, and have "bling" appeal, not for performance.
For my honda, NGK all the way man.
Can't go wrong with NGK plugs and wires and of the O2 NTK....
Never had a problem with them .. I recommande them !!!
Re: Bosch Vs. NGK Plugs (ONEJDM)
The guys at Autowave laughed at my Bosch plugs - said they were the shittest things on the market... Imposible to tune an engine on a Dyno with them -
OEM all the way for 99/00 SI's - why does anyone think a $4 plug will out perform the $25 stock ones???
Re: (Honda97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda97 »</TD></TR><TR><TD CLASS="quote">oem sucks</TD></TR></TABLE>
you suck.
Like said above, NGK and Denso are THE best plugs for Japanese motors.
If you don't think so, you know nothing.
Bosche plugs are crap.
you suck.
Re: (Nameless RB26)
Exactly, Bosche plugs for Japanese motor ( honda) is crap... check the specs for honda, it say NGK for stock or what ever replacement...
For North American cars is ok i guess it's ok to use Bosche plug of what ever but not for honda man ...
Re: (Honda97)
Ya you do suck... sorry
Re: (JDM Ninja)
I duno. I have been running Bosche +2's. My opinion, they are crap! Im getting poor idle, a VERY unstable/unpredictable acceleration on every take off, and not to mention... man, let me tell you... if your a student like me who travels... these fawkers eat 2X's the gas than the original OEM's (NGK).
So, I went to the store, picked up some NGK wires and DENSO (resistor style) plugs... installing them tomorrow... before these pieces of shyt *** up my block!
P.s. the guy down the block is a actual mechanic for over 10yrs, he was like, "NGK or Denso ... unless you want some engine work done down the line!" ill go with the mechanice on this one! DENSO it is!
Re: (Honda97)
**** u u suck</TD></TR></TABLE>
I'd ban you if I could. Moron.
the bosch +4's are also known to have the "extra" electrodes fall off under boosted situations on european cars. You should assume the same for your honda....STAY AWAY!!!!!!! That being said NGK's Are a great plug.
1 Post
Re: Bosch Vs. NGK Plugs (sleepingEg8)
ok this is making me go POOOO ... I have Bosche 4+ and i thought they were great over stock... but all this I hear, boo.. I guess iridium is what I must get soon before something happens, I need money though
