bosch o2 sensor did i wire it right?
hey guys did soem searching but did not find any info regarding wether i wired my o2 sesor up right . Here i got 2 black , one white, one green on the bosch one it has 2 black, one blue, and one white . i wired the 2 blackones together , the blue to the green, and the white to the white , car runs fine except the white wire which i tapped for my air fuel guage now doesn't work !!! Can anyone help me out??????
Thanks will
Thanks will
Re: bosch o2 sensor did i wire it right? (blackccoupe)
Black -> Yel/Blk (Heater Control Positive)
Black -> Grn/Wht (Heater Control Ground)
White -> White wire (O2 sensor input)
Green -> Org/Blk (Heater Control)
Re: bosch o2 sensor did i wire it right? (poison)
so black to black
black-green
white to white
green to black
so i have to change the green to black and the black wire to the blue wire right????
and how do u know what black wire to use?/
black-green
white to white
green to black
i got 2blacks 1 white i green on the stock and 2 blacks 1 blue and one white one the chart u gave me would require threee black's to work ???????
Ok you have:
two blacks
one white
one green on the stock
and
two blacks
one white
one blue
where are you getting three blacks?
Those would color match, just match up the Blue with the Green if you are trying to splice them together using the stock connector plug.
two blacks
one white
and
two blacks
one white
one blue
my bad that is how i got it wired now the blue to green and the others color match but for soem reason my air fuel will not work now the wire for it was hooked to the white i tried that wire and the blue one but neither work for soem reason ?
Air/Fuel should be hooked up to the Heater Control wire (A6). Since that varies in voltage which would tell you your A/F ratios.
ORG/BLK wire is the Heater Control going to the A6 pinout. WHT wire is the O2 input signal (D14 pinout).
hey man thanks for all ur help i really appreciate maybe that gay connector box one of the wires is not contacting but thanks for all ur help !!!!
