boreing out a y8 block would u do it?
alright i got a buddy that will bore out my y8 block for me i dont have to money for a dohc so im going with this. what would u bore it out too? 2.0 or 1.8? planning on turboing it to.
Will you make something up for me please?
Re: boreing out a y8 block would u do it? (96 EX)
Well, do you plan on sleeving the block/cylinders? The stock bore of your engine will be 75mm, you will need at least an 80-81mm bore to get to even a 1.8L. That's way too much on stock sleeves. Honda only recommends boring/honing the block to repair cylinder wall damage to a maximum of 0.020 over, which is only 0.5mm. More than that and you will need aftermarket ductile iron sleeves.
For the price of sleeving ($800+), I would just get a 1.8L block.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 EX »</TD></TR><TR><TD CLASS="quote">so itd be cheaper to just buy a block instead of re-sleeving it and everything else?</TD></TR></TABLE>
Yes sir, definitely. In fact, it would be cheaper to just buy the entire LS motor, not just the block (because then you would need a B-series DOHC head). You can get full swaps for $500 or so. DOHC is better than SOHC.
There are different motors for the 96-00 civics as well, some vtec, some non vtec. And mostly SOHC with the expection of the 99-00 civic si thats DOHC vtec.
Integras came in the LS, SE, GS, RS, GSR and Type-R USDM. If you are talking 94+ i believe the LS, SE, GS, RS all share the same motor a b18b, often just called a LS motor even if it came from a RS etc. Its the same exact motor, I believe the GSR motor is a b18c1, and the Type R is a b18c5...i believe.
Then there are the OBD's, if your car is a 96+ then its ODB2, and you would need a 0bd2 ls motor to swap to make it the easiest, and most legal swap.
Re: boreing out a y8 block would u do it? (swappedcx)
i got a 96ex figure i put a ls in and boost it with greddy headers and catback and all that other goodness whats the hp id be looking at?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 EX »</TD></TR><TR><TD CLASS="quote">i got a 96ex figure i put a ls in and boost it with greddy headers and catback and all that other goodness whats the hp id be looking at?</TD></TR></TABLE>
Okay, stop right there. You need to learn about how turbochargers work. There are no "headers" in a turbocharged system. You have a turbo manifold. You also already have a catback exhaust, you need to determine your goals/budget first before purchasing any turbo/parts.
Re: boreing out a y8 block would u do it? (shamoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo »</TD></TR><TR><TD CLASS="quote">....you need to determine your goals/budget first before purchasing any turbo/parts.</TD></TR></TABLE>
Exactly. Throwing money at it without knowing what your final goal is will end up being a big waste of time and effort (and money!).
I thought Edelbrock makes a pretty comprehensive turbo kit for the D-series engines. Stock internals too. Dyno charts show a 70hp/50lb-ft improvement over a stock D-series vtec with 6lbs of boost. That's according to Sport Compact Car's article in their December 2003 issue.
There are lot of options and ways to go with building/replacing your engine. Figure out what you want to achieve in the long run and work towards it.
project civic
16
07-19-2005 05:05 PM
