boosting
Risky Business
Re: boosting (Dasavior)
Go to the FORCED INDUCTION FORUM HERE --> https://honda-tech.com/zeroforum?id=16
https://honda-tech.com/zerothread?id=716695
keep it under 200 whp, so depending on turbos and setups, id say go safe with 6 or 7 pounds, prolly 10 at the most if its turned like a ****. i myself am now decided on turboing my d16. check out http://www.turbod16.com its a whole site towards turboing d16's
1 Post
Re: boosting (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">Your clutch will give up around 7-8psi. Your block is good to 10 or so. </TD></TR></TABLE>
what do you mean the clutch will give up?
Re: boosting (thrty8street)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thrty8street »</TD></TR><TR><TD CLASS="quote">
what do you mean the clutch will give up?</TD></TR></TABLE>
It means the stock clutch will not hold up to the increased hp
Risky Business
It will start slipping horribly and you wont be able to grab gears as well...then if it gets really bad you can shift gears without using the clutch...then eventually the thing wont grab at all anymore and you'll just rev all day long
safely 7-8 but past that you might as well tear the block down and rebuild it to be safe. but i would decide that before you boost how much you really want and what your goal hp is.
Risky Business
Re: boosting (veganstraightedge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by veganstraightedge »</TD></TR><TR><TD CLASS="quote">safely 7-8 but past that you might as well tear the block down and rebuild it to be safe. but i would decide that before you boost how much you really want and what your goal hp is. </TD></TR></TABLE>
Many people are getting 200+ WHP from stock internals...its all in the tuning
1 Post
so will it still grab a 7psi? or is that still too much?
psi numbers are useless unless you tell us what turbo you will get. the stock block will hold 200-220whp before rods become marginal. Whatever psi it takes you to get to 200-230whp is what psi you should run
Re: boosting (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">It will start slipping horribly and you wont be able to grab gears as well...then if it gets really bad you can shift gears without using the clutch...then eventually the thing wont grab at all anymore and you'll just rev all day long</TD></TR></TABLE>
It'll sound tight revving in your driveway though, blowoff valve going whooosh!!!
95 honda8
11-07-2007 02:54 PM
