Bolting d16 engine to d15 tranny -- Do I need a new wire harness?
Old 09-08-2011, 06:58 PM
CivicDynamo94's Avatar
Icon2 Will it fit...
So here's the thing... I have a 1994 Civic that I need a new engine for (probably) and I need to know... Will a 1.6 liter non vtec engine fit in my car? please explain.
Old 09-08-2011, 07:00 PM
morbius18's Avatar
Default Re: Will it fit...
before you get destroyed, check the FAQ's all the info you wanted is in there about motor swaps (section 6)
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faqs-frequently-asked-tech-questions-1998336/
Old 09-08-2011, 07:11 PM
Master Detailer
98civdx's Avatar
You need to put the question in the title! You will get so much more help that way.
1.6 non v from what car? D16y7?
If so, yes, it will fit, but may require a little work to get it perfect.
Old 09-08-2011, 07:38 PM
ozh_hawaiian's Avatar
will drop in, you might have an issue with motor mounts, and definitely gonna have to changed the motor to odb1 or use the odb2 harness
Old 09-08-2011, 08:04 PM
it is from a D16y7 but would i need to get a new computer for the car to make it work right?
Old 09-08-2011, 08:11 PM
BlackCivicEX's Avatar
If the hole is big enough maybe ....
Otherwise yes fits, lil fit of coverting , couple of wires ran,
Old 09-08-2011, 08:39 PM
I just wish I could know for sure what ill need to do before i drop the engine in there. will it bolt right up to the tranny?
Old 09-08-2011, 08:53 PM
virgineg6's Avatar
Have you checked the FAQs section?
Old 09-08-2011, 08:54 PM
Icon6 Will a D16 angine fit a D15 tranny?
I have a 1994 Civic DX with a knocking rod in which I would like to swap out for a 1.6 liter non vtec engine. Here's my dilemma... I have no idea if this swap will work. What can I do to make this swap work (besides buying a new tranny to fit the engine)?
Old 09-08-2011, 08:55 PM
Katastrophic's Avatar
Default Re: Will a D16 angine fit a D15 tranny?
as said many times, D series engines work with any d series trannies, B series with B series, H/F series with H/F series and Ks with Ks.
In short, yes the D15 tranny should bolt up to the D16
Old 09-08-2011, 09:06 PM
virgineg6's Avatar
x2, did you try searching? FAQs section has tons of useful information.
Old 09-08-2011, 09:11 PM
Should and will are two different things though. and im new to this website so please tell me wtf FAQs is bub. lol
Old 09-08-2011, 09:28 PM
Plus... Do I need a new wiring harness and manifold and everything also to make the transition work?
Old 09-08-2011, 09:35 PM
Master Detailer
98civdx's Avatar
The transmission WILL bolt on.
virgineg6's Avatar
Its a sticky on the 92-00 civic section page
https://honda-tech.com/forums/showthread.php?t=1998336
Old 09-08-2011, 09:42 PM
FAQ or Frequently Asked Questions, On HT is a list that practically covers any and everything you'd ever want to know or try with your civic, and i mean ANYTHING. Ps. i said should because something can always go wrong or your tranny could have some unforseen damage of some sort. (Never know, Hypothetical)
But will I need the new wiring harness? Because i don't see how that FAQs section will help me with that paricular question
Old 09-08-2011, 09:45 PM
Texas4door's Avatar
I think it depends on if it's an auto or a stick...less wiring with sticks, dontcha know ^^
Plus I think the plugs for the wires are probably a different shape too...
Old 09-08-2011, 10:09 PM
well im lookin for tha automatic wiring harness.
Old 09-08-2011, 10:10 PM
will it need a new wiring harness if its for the automatic??
Old 09-08-2011, 10:15 PM
Icon2 Bolting d16 engine to d15 tranny -- Do I need a new wire harness?
If I am bolting a d16 engine up to a d15 tranny will I need a new wqiring harness to go along with the hook up?
Old 09-08-2011, 11:04 PM
Shadowe622's Avatar
well is the motor from the same year car or not? if its a obd1 d16 with a ob1 car the wiring shouldnt be much different. But you didnt specify where the d16 came from.
Old 09-08-2011, 11:21 PM
usdmed9's Avatar
Default Re: Do I need a new wiring harness?
You will use your stock harness but depending on what year car vs. engine as well as what d16 will depend on if you have to change any of the wiring
Old 09-09-2011, 06:36 AM
Master Detailer
98civdx's Avatar
The transmission does not decide if you change the harness, unless it's a auto. If it is, your going to have alot more then that to worry about.
Old 09-09-2011, 06:54 AM
Master Detailer
98civdx's Avatar
Is the car a auto?
This is why you need to include this info in the first damn post.
Quick Reply: Bolting d16 engine to d15 tranny -- Do I need a new wire harness?
