bolt is stuck!!! what do i do??
i'm doing my turbo install and i just went to pull the fuel rail to put in the 450s and the middle bolt of the fuel rail will not come off. i broke it loose and it spins but it will not come off. i'm out of creative ideas... hopefully you guys can help out. thanks in advance
-Zach
edit: it is a very tight fit as you might know. the throttle cable is there as well as the top of the intake manifold.
-Zach
Munkyw3rkz.webs.com
1 Post
Re: bolt is stuck!!! what do i do?? (94c1v1cex)
is it a stud with a nut or a bolt?
first if u can get a small opened wrench on the backside of the head pulling it up as u turn it to see if it will catch...
if not remove the IM and drill and use a easy out on it.... once removed see how the treads look if anything u have to retap it
tighten it down as much as you can.. spray liquid wrench or wd and let it sit for about 2 min. then spray it one more time. wait 2 more min. then it should be off
Re: bolt is stuck!!! what do i do?? (S@nt0s)
Drilling and re tapping is your best bet if you cant soak it, Id say heat it up with a torch but since its location is near fuel that wont be a good idea.
it's a stud off the intake manifold that the fuel rail slides over and then a nut holds it down.
thanks for the input. i'll give it a shot
Munkyw3rkz.webs.com
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94c1v1cex »</TD></TR><TR><TD CLASS="quote">it's a stud off the intake manifold that the fuel rail slides over and then a nut holds it down.
thanks for the input. i'll give it a shot</TD></TR></TABLE>
in that case, the nut nad stud both are spining right
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s »</TD></TR><TR><TD CLASS="quote">
in that case, the nut nad stud both are spining right</TD></TR></TABLE>
nope just the nut... the stud is staying still
believe it or not brake fluid works pretty good for getting **** loose, i just did a rear disc conversion and it came in handy for me, either that or "rust-off" by WURTH works good too for that ****
Munkyw3rkz.webs.com
1 Post
nope just the nut... the stud is staying still</TD></TR></TABLE>
apply some pressue behind the nut with a open end wrench whilte turning it counter clockwise
Re: bolt is stuck!!! what do i do?? (circuitEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by circuitEG6 »</TD></TR><TR><TD CLASS="quote">believe it or not brake fluid works pretty good for getting **** loose, i just did a rear disc conversion and it came in handy for me, either that or "rust-off" by WURTH works good too for that **** </TD></TR></TABLE>
just be careful not to get that **** in your eyes LOL **** happened to me it burns like a ************!
this could be taken as a dirty conversation....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s »</TD></TR><TR><TD CLASS="quote">apply some pressue behind the nut</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suicide_shift »</TD></TR><TR><TD CLASS="quote">just be careful not to get that **** in your eyes LOL **** happened to me it burns like a ************!</TD></TR></TABLE>
how am i supposed to be do this in a space that's 5 inches wide? i can't even get my hand in there
Accord15
12-09-2002 02:04 PM
