Bogging when Im on the throttle
I hve a civic 00 with a b16 swap and everytime I get off first and second etc my car boggs abd jerk hard. I had 87 gas before so I been riding on that. Do you think that can be the reason ?
Re: Bogging when Im on the throttle
The only reason octane would cause that much of a problem is if the timing was already off. Does it bog down more at low RPM, like flooring it from a stop? List any mods.
When I'm about to get off of first and second, I would step on the throttle and it would jerk the car a lot.. Well I know I have my stock d series injectors but they are from a vtec motor. But I heard that since I'm using the wrong gas. That's the reason my car is actin up
I had that problem for a while, running higher octane helped, but it was still there. Then I found out my dizzy was bad.
I have had this issue before with my D-series. I checked the plugs and found that there was little to no electrode left, changed them, and the car ran perfect. Its a 5 minute check that may be something to consider.
its either your dizzy or spark plugs more than likely. never hurts to change plugs and wires and the cap and rotor can only benefit you
EntuneCrx
09-26-2005 08:05 AM
