Blower question
Blower question
Hey guys I am pretty new to the bored and really to hondas. My girlfriend has a 98 civic two door and she is having problems with her air/heat system. I searched a bit but it seems the only results with blower motor were a few F/S and a guy the swapped systems.
When she turns the fan on it makes an awful noise. The slow speeds seem to be louder then as you turn the fan up the noise eventually goes away.
I think its something to do with the blower motor area. Anybody have this experience before or have suggestions/ideas.
Is it easy to replace the blower motor(car has A/C).
Your help is appreciated
Edit: Just relized there is an archived button in the search. I will go back and look
Re: (-Gary-)
Thats what I was thinking. I found an online service manual and it looked easy. Is there a certain post that has any pics of the process. There are 133 results to dig through on the search.
Re: (ek forever guy)
I have seen instances at work where leafs and debris gets into the fan area and make noise as the cage is rotating over the leafs. Worth the time (very easy) to drop it down and see if theres anything in there that would be causing a noise
Good luck
Good luck
Re: Blower question (philpsu)
i just had to replace mine because the plastic fan was messed up and it was rubbing on the inside wich made a loud noise like you were sayin. i picked one up a junkyard and cost $37.00 and dont have the problem anymore. i have a 94 and it was 4 phillips to take off the glove compartment and 3 phillips screws to pull down the blower motor and 1 plug to disconect it was real easy.
Just thought I would let everyone know that I replaced the blower motor this weekend. It didn't take to long and there was a stick in the blower wheel but the motor was still the culprit.
One thing that I never saw mentioned in any post about blower motors was how to remove the blower wheel from the blower motor.
I thought there was some sort of clip after removing the retaining ring but all you do is just lift up on the wheel from underneath with two screw drivers while tapping the center post until the wheel slides up off the shaft.
Thanks for the help.
notnilc20
01-23-2017 05:05 PM
