Blocked Exhaust
Blocked Exhaust
I left my car for a week when I left for vacation and now the car has been idling really low. I changed my plugs and and nothing. The air filter is fine.
When I start the car up it sounds like it isn't allowing all the exhaust out... I put my hand at the exhaust and it doesn;t have much coming out.
My question is do you think this could cause a low idle?? when I am stopped at a red light it sounds like my car is going to stall but it doesn;t. On the tach it says its just above zero.
Re: Blocked Exhaust (viper1984)
did u try turning ur idle up a little and see what happens. or if u think something is in the pipe put it in first gear take off and red line it see if it clears it out. i never heard of this type of problem.
i wouldnt mess with the idle at all....if you arent getting good flow out of your exhaust pipe you have a clog somewhere..id start with the CAT and work from there
Re: (5_Lug_B)
I had the same problem w/ my boss's RT-10 Viper except it wouldn't start - a mouse...or mice crawled up into the exhausts and built nests (it sat in the garage for a year or two).
Fix = started it up at full throttle and it splattered guts all over both garage walls .
Alright, in more important events...is it starting up okay? If so, how is it besides the idle? Pulling okay? Is the idle just LOW or is it "hunting?"
Re: (Syndacate)
ya everything is running fine other wise. I did try reving it at high rpms but nothing. I will check the cat and see if that might be it.
kylelovesbass
05-20-2014 07:25 AM
digital sol
06-30-2009 07:11 PM
imnotswapped
10-12-2003 10:06 AM
