blinking noise .../ gas pedal
I have a problem with my turn signal, it makes the sound but signals are not. On. Its getting anoying , anybody had this problem before ? And. One more problem ..whenever. I step on the gas and rev it or just speed. The gas pedal gets stuck . Anybody has a clue ?
Re: blinking noise .../ gas pedal
What year Civic? Do all the hazard light work?
Gas pedal sticks:
Check whether the throttle cable is adjusted too tightly. If that's fine, then clean the throttle body and possibly replace the throttle cable.
Gas pedal sticks:
93 cx blinkers work. And hazard does too .. at first its a fast blink but then it gets slower and it varies
when the blinker gets fast..go check which bulb isnt lighting up or which bulb is on constantly.
from there replace the bulb.
as for the gas pedal issue follow ron's guide. all my issues with frozen gas pedals have been the stupid floormat holding them down so i guess check that as well
The noise its there as. Long as the car its. On but everything works. Fine (turn signals,and hazard) as for the gas pedal there's no carpet or floor mats
So you hear a ticking noise that sounds like the blinkers but the blinkers and hazards work perfectly fine, right? Do the gauge assembly signal indicator lights also blink?
no on the gauge indicator theres no light or no blinks i checked the relay and the relay blinks and the fueses are ok the relay was replaced too as well and noise still there
Nick M
14
04-22-2006 08:26 AM
