Blinkers not working...
Well today I was taking apart the part of the dash board on my 1994 Civic Ex (I followed the instructions layed out by Bauley in THIS THREAD) so I could clean my Gauge Cluster Cover a bit.
The previous owner had a sticker over the Speedometer for some crazy reason, pealed it off and left nasty residue. I was attempting to clean this off.
Anyways, put everything back together, went for a drive to cash a check... And no Blickers, and no Hazards. Everything else worked fine.
Got home and checked my re-assembly again... I somehow pushed one of the prongs on the Hazard switch up, so I corrected it, plugged it back in... Hazards work, no blinkers still.
Checked all of the fuses under the dash and couldn't find a Blinker fuse... Can anyone help with this situation?
Thanks in advance,
Thanks in advance,
Re: (ZedEx)
i also have a blinker problem, just one blinker in the front though, and the light works, just not the actual blinker...if that makes sense, so id like to know too
dAng!
Re: (Dave The Flave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave The Flave »</TD></TR><TR><TD CLASS="quote">i also have a blinker problem, just one blinker in the front though, and the light works, just not the actual blinker...if that makes sense, so id like to know too</TD></TR></TABLE>
have you had the relays checked? The same goes for the original poster.
I'm now almost certain it's one of the relays... Because right after I posted this thread, the blinkers are working.
Sounds like a relay to me... Damnit, that's two this month
bad bulb, or bad connection probibly.
original post.
if you had the hazard switch out and bent one pin, what are the chances one of the other pins are still bent?
the turn signals run though the hazard switch.
there is only one relay involved in the turn signals, the blinker itself.
And if it's a fuse your clock will not come on with the ignition and your reverse lights will not work.
original post.
BlackYoshi
20
03-27-2009 07:49 PM
DomDomBoy
10-20-2001 03:19 PM
