bleeding/purging?
bleeding/purging?
ive looked it up, and ive figured out that ive got air in my injectors, and i cant figure out how to bleed them.... and ive looked it up but i cant find anyways on doing it, so any help would be thankful...
Re: bleeding/purging? (canis)
Say What???? that might be a problem if the car is diesel but your car should be gas. the only way you could be getting air into the lines would be sucking it through a crack in the line or fitting but you would have a fuel leak. So the only place I think you would get air in the injector would be a bad oring seal around the injector or a problem in the supply line in the fuel tank hope this helps. So I think your problem could be some place else. What is going on and what test have you done?
Re: bleeding/purging? (instructor74)
well i just got back from iraq, and i was there for about 8months so its been sitting, and i checked all the systems on my d16z6 motor, and did a few standered things like timing belt, oil, filter, fuel filter.... i got compresion, air, and spark but i cant tell if im really getting feul, i tested the injector and there inside what they should be... so my car turns over, but wont start, i got a good battery and starter, so i have no clue what it might be?
FearTheH
11-15-2009 06:02 PM
S2k Hybrid
12
04-24-2007 09:41 PM
