Black smoke, mild idling issue
Old 01-07-2019, 03:11 AM
Default Black smoke, mild idling issue
Guys as mentioned above, having those problems, which is giving me bad mileage in addition.
its a civic EH aka EG, whose engine was swapped by the prevoius owner, no details of swap ! I found out that its a SO4 from ZC series, Jdm i believe. 1.6 SOHC, manual.
it was not smoking when i got it afew months ago. I had the timing belt changed, also drained the radiator liquid which was plain water and filled with Honda all season coolant type two. I dnt know exactly how long after this it started to smoke, the idling as well.
in solving the idling issue, i had the throttle body cleaned ( the mech just sprayed sm substance ) . But the idling issue was still there. From this point on i realised that the engine was smoking.
From the time i bought the car, the CEL was flashing, so decided to check on the error code, which ended in me changing the distributor, upon which the CEL disappeared. ( the distributor was a recon set, it gave me **** and engine died on the road ! Changed another two and its running now)
Hence the issue of smoke and idling persisted, reading forums guided me to change the coolant temp valve and a clean up of the idling control valve. On the first start it seemed that idling had disappeared, but it s still there, but not as bsd as before. The smoke however is still the same or even worse.
I dnt know if the issue persists because the coolant temp valve being not a genuine part, is not doing its job or what. Also the cleaning of the idle control valve was done while the coolant tubes were still attached.
i am thinking of the valve which is on the exhaust manifold, if thAt could be the culprit. The mechanic seems to suggest that it could be the ECU, which needs to be checked.
i am. beginning to wonder if it was the coolant which i emptied into the radiator is csusing the smoke ( four bottels of Honda all season anti freeze type 2, without mixing water) as in if the radiator has had a shock as it is used to plain water ! Ha ha.
also the plug cables need a replacement, could this add to the issiue ?
What do you guys suggest ?
Edit: its a non vtec
redhatcode29 is offline
Old 01-07-2019, 04:09 AM
DaX
DaX's Avatar
Default Re: Black smoke, mild idling issue
Black smoke is typically a sign of running rich. Pull your spark plugs and look at them.
DaX is offline
Old 01-07-2019, 05:10 AM
i think its obvious that i am running rich. How do i cure it
Old 01-07-2019, 05:36 AM
muellersfan's Avatar
Measure the fuel pressure, test the FPR, and check for a stuck open fuel injector.
Post what ECU is running the ZC engine. Is it a VTEC or non-VTEC engine?
https://en.wikipedia.org/wiki/Honda_D_engine#ZC
muellersfan is offline
Old 01-07-2019, 05:59 AM
DaX
DaX's Avatar
Pull your spark plugs. If one cylinder is obviously running richer than the others, you can likely narrow it down to a bad fuel injector. If they're all soaked in fuel, it may be a bad FPR.
DaX is offline
Old 01-07-2019, 06:07 AM
Old 01-07-2019, 06:27 AM
thank you. Will try that. Noob here, what is FPR may i ask ? Thanks.
Old 01-07-2019, 06:47 AM
Fuel Pressure Regulator
It is on the fuel rail and connects to a vacuum hose and a fuel return hose.
The FPR adjusts the fuel pressure to match the engine load.
Too high fuel pressure will make the engine run rich.
Old 01-07-2019, 08:49 AM
sorry i missed your post earlier, so thats fpr. Ill have to check on the ECU, not that i know how to 😀. Will look it up. My bad, i did not mention that it is Sohc non vtec. Will check on the link. Appreciate it.
Old 01-07-2019, 08:50 AM
thank you.
Old 01-07-2019, 10:39 AM
If no VTEC code is thrown, then a P06 ECU for a D15B7 engine is likely installed. But itís still wise to check.
Old 01-07-2019, 02:00 PM
Originally Posted by demon6666699999 View Post
If the FPR was stuck open
I think you meant to say "stuck closed". That is, the fuel pressure is not relieved by the FPR releasing it to the fuel return hose.
I doubt the pump could put out enough pressure to force the injectors to leak.
Not to leak, but to pulse more fuel than required when signaled by the ECU.
Old 01-07-2019, 02:02 PM
Prob. a injector or primary 02.
demon6666699999 is offline
Old 01-08-2019, 04:57 AM
Check for gas leaking through the fuel pressure regulator to the vacuum hose. That gas would go into the intake and make black smoke. Black smoke means that a LOT of excess fuel is going into the engine.
mk378 is offline
redhatcode29
10-29-2018 07:08 AM
K_Simm_94LX
03-31-2011 10:23 AM
fa5VSeg8
03-08-2011 03:29 PM
Nortonfan
08-18-2010 09:32 AM
tacorunner87
12-16-2009 01:49 PM
Quick Reply: Black smoke, mild idling issue
  • Ask a Question
Question Title:
Description:
