Bitch Bolt from shift linkage to Tranny please help!!!!!!
i recently did an engine swap, however while trying to put the shift linkage back on, i lost the dowel pin the tighten the shifter. anyone have any idea where i could possibly find one of these?
Re: Bitch Bolt from shift linkage to Tranny please help!!!!!! (d15vtecivic)
Well i found a site, but i dont know where the bolt would be located, it is the only Dowel pin you take out when you disconnect the Tranny, If anyone wouldn't mind helping me and locating the pin from this site i would be EXTERMLY appreciative Thanks you all for reading this, Thanks, Dave the website is http://www.slhondaparts.com/br...5MTKA
Its a really helpful website!! |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d15vtecivic »</TD></TR><TR><TD CLASS="quote">Well i found a site, but i dont know where the bolt would be located, it is the only Dowel pin you take out when you disconnect the Tranny, If anyone wouldn't mind helping me and locating the pin from this site i would be EXTERMLY appreciative Thanks you all for reading this, Thanks, Dave the website is http://www.slhondaparts.com/br...5MTKA
Its a really helpful website!!</TD></TR></TABLE> its part 23... http://www.slhondaparts.com/br...=true |
Re: Bitch Bolt from shift linkage to Tranny please help!!!!!! (bmoua)
thank you so much!!! your a beautiful young man lol jk
Re: Bitch Bolt from shift linkage to Tranny please help!!!!!! (dubnine)
somebody beat me to it...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d15vtecivic »</TD></TR><TR><TD CLASS="quote">thank you so much!!! your a beautiful young man lol jk</TD></TR></TABLE>
n/p bro https://honda-tech.com/forums/images/smilies/emthup.gif |
is that the bitch pin i keep hearing about?
Is the bitch pin the same for d series and b series?
Re: Bitch Bolt from shift linkage to Tranny please help!!!!!! (SiYouLater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiYouLater »</TD></TR><TR><TD CLASS="quote">Is the bitch pin the same for d series and b series?</TD></TR></TABLE>
yes |
Re: Bitch Bolt from shift linkage to Tranny please help!!!!!! (DeadEnd9009)
It's called the "devil pin 666" at my house. Once you deal with them 4-5 times they are cake, though.
Re: Bitch Bolt from shift linkage to Tranny please help!!!!!! (Hatchy-Ownzjo0)
Don't they make a modified C- clamp tool that removes the bitch pin very easily?
Re: Bitch Bolt from shift linkage to Tranny please help!!!!!! (Blue-Civic-Hybrid)
The right punch and a sledge hammer will do the trick! I've done so many that way and had no problems... https://honda-tech.com/forums/images/smilies/emthup.gif
ps It helps if your car is about 2 1/2 to 3 ft off the ground. |
I seem to be able to get it out easy, if i use a good punch.The punch needs to be about the same size as the hole, on the shift linkage. just my 2 cents
8mm non tappered punch is your friend when removing the "bitch pin"
Re: (egsleepercivic)
air hammer y0
8mm roll pin for the fucking loose. I hate those things.
Re: (Eran)
fuk punches, a/c bolt ftmfw
Re: (DFW)
dont understand why everyone thinks that is such a bitch to get out word of advice to all get a 92-95 civic ac compressor bolt you know the one that bolts it to the block and use it to remove the pin its the perfect size and does no dmg to pin
