Biggest SOHC Throttle Body
Re: Biggest SOHC Throttle Body (Radyjr)
what you need to do is get a gsr tb. ok you following thennnn use a dremel tool to bore the inside of it out prob a good 3mm. i did it. makes Yo VtEc Scream.
Re: Biggest SOHC Throttle Body (menkio)
i would say 150mm, but that might be a little big for your application...
and i agree, god i hate life
Re: Biggest SOHC Throttle Body (Soccerking3000)
damn you guys are ******.
Most b-series throttle bodies are interchangeable with the d series throttle bodies. Get one off a b16 and then have it bored.
jesus tapdancing search il get you started read this thread
https://honda-tech.com/zerothread?id=1024818
You don't wan the biggest throttle body out there. If you don't have a boosted motor I wouldn't go past 62mm... If you go to big your going to loose horsepower... If you do have a turbo I would do 68mm throttle body if your running a lot of boost.... If not a 64 mm would be great for a turbo setup... Size doesn't matter in this sittuation.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Radyjr »</TD></TR><TR><TD CLASS="quote">What is the biggest throttle body that fits on a D16Z6 Intake Manifold. </TD></TR></TABLE>
You dont have to used a SOHC tb.
kenepo_vtec
01-31-2005 11:11 PM
