Big Problem need help on next instalation!!!!
right now i own a Champ whtie 98 civic hatch DX i just got done lowering my car and was wondering what should i do with the rest of the money i have saved up should i buy a camber kit shocks or save up and get a CF hood. to be honest i dont know what a camber kit is for but just wondering what should i do next thnks
Re: Big Problem need help on next instalation!!!! (dirtyapes)
Bump
get the camber kit and have an allignment done.
A camber kit is for when you lower your car too much and the wheel is bending into the wheel well. The camber kit adjusts this problem so you don't have to buy new tires every 5000 miles. How much did you lower it? Is you have this problem then spend your money on a camber kit and have it professionaly adjusted. What is everything you have done to it?
Re: Big Problem need help on next instalation!!!! (B18C1 Del Sol soon)
so far i have got the champ white done, MINI me swap DC headers injen intake, ITR front lip. lip sde moldings and mirrors hvae beent painted to match. CTR spoiler. si disk brake conversion, SI seats si tweeters si automatic window conversion, electric mirror conversion lowered on skunk 2 coilovers. but if i get the camber kit and the alingment done do i have to raise my car. its pretty low to so let me know thanks. also how much should i expect to spend on a camber kit
Spend = approx. 200$
For the 200$ you spend now it will save you THOUSANDS in tires in the future. The most adjustment I have seen on a camber kit is about 3 degrees. Your car has to be really low to be off by more than that. So most likely you won't have to raise it up. |
No the car will not be raised at all, the camber kit just adjusts the inward and outwardness of the wheel. You should expect to spend between $150 and $220.
so when i go to ge tit installed just tell the shop to also do the alingment to. also this is totally off subject but i was wondering if any of you know how to post pics online my friend has a digital cam and wanted to post picks of our crews rides on here thanks
Yes as long as the shop is competent to imports they should be able to set it up for you.
As for pictures http://URLofwherepicishosted |
for the pictures u can uplaod them to http://www.we-todd-did-racing.com or any other image hosting site. then copy the URL of the pic and paste the URL into img brackets like this
[ img ] URL HERE [ /img ] with no spaces |
Re: Big Problem need help on next instalation!!!! (99FBPSi)
Not to be an ass, but I get the feeling that you've done absolutely none of the work on your car yourself, right? Where the fun in that.
