big problem! d15b swap
I swapped my jdm d15b vtec into my 92 civic dx hatchback and it is running. it has a rough idle, and bad throttle response. the timing is on at idle when you start the car, but then you hit the gas and it will start idleing rough after that and be out of time. i do not have a vtec ecu, i just have the stock one. Oh, and when driving you can not maintain a constant speed, itll jerk. please help
Re: big problem! d15b swap (mnneon)
TPS and MAP switched?
Try running a VTEC ECU? |
Re: big problem! d15b swap (duggy)
Run the correct ECU then get back to us.
ok, thanks, ill do that
Re: (mnneon)
I had this problem with mine when i did my swap i had a couple of wiring harness plugs mixed up. i would go through and check that first, there should be one extra plug for the charcol canister that you no longer need.
Re: (IA95civicDX)
which ones were messed up?
yep, get the correct ECU...that's your problem
i just ordered it
could it be the tps? air pockets in the coolant? anything else i can trouble shoot until my ecu comes?
when you get the new ecu plug it in reset it and you shouldn't have no check engine light if you got 1 then go from there may be sensors plugged in backwards
Re: (Slammed92hbonN20)
most definitely your ecu.
relax untill you get the new one, and if the problem persists let us know https://honda-tech.com/forums/images/smilies/emthup.gif |
k, thanks everyone! i hope it all works out.
the timing is way off i think. that is the problem
it's not your ecu. I've done this swap a few times and kept the stock ecu with an rpm activated switch to engage the vtec and everything worked just fine. Did you lengthen the coolant temperature sensor wires and plug it in?
Re: (coquitlamEG)
Check the cam timing while you're at it https://honda-tech.com/forums/images/smilies/emthup.gif
Re: (coquitlamEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coquitlamEG »</TD></TR><TR><TD CLASS="quote">it's not your ecu. I've done this swap a few times and kept the stock ecu with an rpm activated switch to engage the vtec and everything worked just fine. Did you lengthen the coolant temperature sensor wires and plug it in?</TD></TR></TABLE>
That would run like crap. No vtec maps means you are not getting the performance the engine is supposed to get. Yes, you are engaging vtec but on the stock maps http://images.honda-tech.com/set1//smile/emcrook.gif |
"That would run like crap. No vtec maps means you are not getting the performance the engine is supposed to get. Yes, you are engaging vtec but on the stock maps"
You've obviously never done this swap before. He said it even runs rough at idle. Both motors are the same size and would run perfectly fine off the same ecu. The vtec ecu would definatly give a little more fuel in vtec but wouldn't even come close to explaining the problems he's having. |
Re: (coquitlamEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coquitlamEG »</TD></TR><TR><TD CLASS="quote">"That would run like crap. No vtec maps means you are not getting the performance the engine is supposed to get. Yes, you are engaging vtec but on the stock maps"</TD></TR></TABLE>
um, no you're not dude. I would explain, but I'm tired and pgmfi.org never sleeps https://honda-tech.com/forums/images/smilies/emthup.gif |
If your runing a P06 ecu (you stated you have a DX civic) then the ECU is Not the problem. I have run my P06 on my D15b without any problems (other then having no vtec)
the motor runs the same with the p06 and the p28 from phaerable.net or whatever...
i don't know how to change the cam timing. i know how to do the dizzy but not the cam. i changed the timing belt so i think i didn't do right. is it bad to drive when timing is off? |
coolant temp sensor? everything fit without extending. although i do have 1 extra plug, it is the same amount of pins as the iacv sensor
got the timing set woohoo. runs good, just need a new 02 sensor
Re: (mnneon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mnneon »</TD></TR><TR><TD CLASS="quote">the motor runs the same with the p06 and the p28 from phaerable.net or whatever...</TD></TR></TABLE>
..except that it's not engaging VTEC. gratz on fixing your prob https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: (SpydiR)
thanks. now i just need to get 2 new front tires and itll b driving. woohoo
haha the hero! |
