Big List about B20...
i have a 95 (obd1) civic... it has a (obd2) ex motor.. wired up and runs great..
1. Should i get the B20B or the B20Z?
2. Do i need to change tranny's?
3. If i do.. what tranny do i get?
4. I heard i have to change the shift linkage.. what one would i get?
5. Ls intake manifold? if so obd1 or obd2?...remember my car is wired for obd2..
6. What wiring harness would i use? i heard about using the crv harness but it wouldn't plug into my car because its an obd1...
7. What ecu would i need to get? can i just keep my p28?
8. Which axles?
9. What fuel injectors do i use? what about fuel rail.. or anything else on the intake manifold that i need to swap?
10. Do i need a knock sensor?.. do the engine have one? i think i have one can i use that one?
12. When i put this motor in my car what other wiring problems will i face.. also what other problems or concerns are there?
any imput would be helpful thanks brett...
8. Which axles?
Re: Big List about B20... (d16y7vtec)
not too sure about your car but you will need ls intake manifold,integra trany and shift forks(which tranny you get will depend on your goles in the long run), axels and intemedit shaft should match the tranny for best fit and i beleive that you will need to change the drivers side upper mount bracket to a 94 up gsr, and as far as wiring goes you could change the harness from your moter to the b20 and be set and you will not need a knock sensor aslon as you run an obd1 ls ecu
use the serch function
i am also going to get a gsr tranny...i read those are the best...so what linkage would i use?
[Modified by d16y7vtec, 4:08 AM 8/16/2002]
you can use either GS-R or LS linkage...are you doing all motor or turbo?
LS tranny is your best bet for turbo
Type R or Si trannies are best used all motor
GS-R is good as well
Unceasing Measure
Re: Big List about B20... (ef ect)
not too sure about your car but you will need ls intake manifold,integra trany and shift forks(which tranny you get will depend on your goles in the long run), axels and intemedit shaft should match the tranny for best fit and i beleive that you will need to change the drivers side upper mount bracket to a 94 up gsr, and as far as wiring goes you could change the harness from your moter to the b20 and be set and you will not need a knock sensor aslon as you run an obd1 ls ecu...use the serch function
gnccracer20
03-22-2009 09:25 PM
