best way to tighten bolt
whats the best way to tighten the crank bolt and cam gears? i was thinkin maybe when i have the engine in the car? what to you guys think? thanks!
Re: best way to tighten bolt (1BADEGDC2)
It's your call, when it's in the car you can hold it up better - but if it's out of the car you have more access to it.
ok, but if its out the car how do i keep it from moving? the only reason i would wait till its in the car is because thats the only way i can think of that nothin will move ... thanks
Re: (1BADEGDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1BADEGDC2 »</TD></TR><TR><TD CLASS="quote">ok, but if its out the car how do i keep it from moving? the only reason i would wait till its in the car is because thats the only way i can think of that nothin will move ... thanks</TD></TR></TABLE>
an engine stand should do the trick...
Re: (krtejsohc)
i found it the easiest to do when the engine is out... it is easier to get to and its easier to keep from spinning. cams gears are the same you can hold the opposite end of them and tighten it down.
i did click it and its a forum, but of what??
and i had it on a stand, but when i tighten the bolts the cams move, or the crank pulley ... i need to torque it down and i cant since it moves, if i try and jam somethin in the flywheel to hold it, it only works for a lil then it spins again
Panoply
08-03-2008 04:13 PM
accurate
21
04-13-2004 05:23 PM
