Best tranny for D16 turbo?
Old 03-25-2003, 01:38 PM
MisterTurbo's Avatar
Default Best tranny for D16?
Does anyone know what tranny would be best for a D16 EG Civic Turbo? Is there one with an LSD that would fit? Thanks.
[Modified by MisterTurbo, 10:41 PM 3/25/2003]
Spade's Avatar
Default Re: Best tranny for D16 turbo? (MisterTurbo)
96-00 Civic EX.
Cannot beat the steel shifter forks.
Old 03-25-2003, 01:40 PM
Kamin's Avatar
the stock tranny is fine
there is no honda SOHC transmission with LSD that will work (that im aware of)
Quaife makes one for the d16z6 motor but its pricey, 895$ list price. most people will say its well worth it.
Old 03-25-2003, 02:05 PM
importfan2's Avatar
Default Re: Best tranny for D16? (MisterTurbo)
Or you could get a phantom grip lsd which only goes for under 300
Old 03-25-2003, 02:28 PM
piscorpio's Avatar
There was an older d15 I believe, that came with LSD stock. I do not remember specifics, but you can search the source that I read it at: http://pub143.ezboard.com/bhondadseries
This is helpful also: http://home.cinci.rr.com/mistab0ne/tranny.html
[Modified by piscorpio, 5:29 PM 3/25/2003]
Old 03-25-2003, 02:36 PM
JaeOne3345's Avatar
Default Re: Best tranny for D16 turbo? (Kamin)
JDM d15b sohc vtec from the VTi came with oem lsd. rare yes, but it is out there.
for turbo i would go no less then 92-00 sohc vtec trannies. these trannies are no better then LS trannies gear wise and we all know how wack those are (unless you are pushing major boost that 'longer is better for boost' doesnt really mean much,)
Old 03-25-2003, 02:38 PM
Loco Honkey's Avatar
Default Re: Best tranny for D16? (importfan2)
Or not?
Old 03-25-2003, 02:44 PM
Red AEM Civic's Avatar
The phantom grip lsd sucks huge major *****, i wouldnt get one for free. it ***** the tranny up and breaks easily.
Old 03-25-2003, 02:48 PM
pg_thao's Avatar
Default Re: Best tranny for D16 turbo? (JaeOne3345)
what about the dx tranny with 12lbs of boost on a t3?
Old 03-25-2003, 03:19 PM
JaeOne3345's Avatar
Default Re: Best tranny for D16 turbo? (pg_thao)
try to get an ex/si sohc vtec tranny
Old 03-25-2003, 03:21 PM
2faz2paz's Avatar
ya get the 96+ ex tranny the 92-95 have aluminum shift forks which break pretty easy and the 96+ has steel.
Old 03-25-2003, 05:31 PM
piscorpio's Avatar
Default Re: Best tranny for D16? (piscorpio)
If you check the link I posted, you can see how an EX/Si tranny can be improved even greater...if you can stomach the work.
Old 03-25-2003, 05:49 PM
flat-blk-HB's Avatar
Well **** I learn new things everyday...I had no idea that the 96+ trannies had steel forks..Glad i got the whole d16y8 swap for my 92
Old 03-26-2003, 07:36 AM
pg_thao's Avatar
if the dx tranny, will it slow down my spool time or what?
Old 03-26-2003, 07:43 AM
RyanEJ8's Avatar
Default Re: Best tranny for D16 turbo? (Spade)
96-00 Civic EX.
kommon_sense's Avatar
Most likely because longer gears will take longer to accelerate. So it will take longer to reach the point where your engine makes enough exhaust to spool the turbo. I don't know how big of a deal that is, but if you can get your hands on a better tranny, that would be a good thing. You could always throw a new clutch in while you are at it. You are gonna need one for a turbo.
[Modified by kommon_sense, 11:46 AM 3/26/2003]
Old 03-26-2003, 09:15 AM
omahaturbocivic's Avatar
Just switch from dx tranny to ex tranny on my turbo d16z6 and it made the world of diffence, probably the best thing I have done for my car in a long time. 2nd gear would bog till the turbo spooled, now its instant pull in second gear and 3rd gear pulls soooo much stronger!
Old 03-26-2003, 09:18 AM
RyanEJ8's Avatar
JDM D15 LSD tranny. Very hard to find though. I saw one for $800 on dseries.org less than a month ago.
Old 03-26-2003, 09:54 AM
Default Re: Best tranny for D16 turbo? (RyanCivic2000)
Thanks for all the feedback. I'm going to keep an eye out for a D15 LSD...
Old 02-03-2007, 10:35 AM
00WhiteEKy's Avatar
sorry to wake this thread up, but I was wondering about the 96+ HX trannys. they have the big bearing case. But they have longer gears than then ex tranny because the hx was made for MPG. But when your boosting, longer gears are better, aren't they? Stay in boost longer. correct me if im wrong.
I have a 98 ex running 10lbs. My bearing my tranny is getting really bad. I do have a loner HX that i could swap trannys. But any feed back would be nice. I just don't think the longer gears would really be a plus for me, because its not like the ex gears are that short.
Old 02-07-2007, 09:40 PM
VolkswagenWHO!!!'s Avatar
use a Ex tranny with an aftermarket LSD
Old 02-07-2007, 09:47 PM
* B A N N E D *
spork motorsports's Avatar
Default Re: Best tranny for D16 turbo? (92hatchy)
stop bandwagoning this kid, the oem d15 lsd is not good, internals arent swapble with any other d series trannies, and they're weak as expletive
whats this **** about 96+ steel shifter forks are better didnt bense already post a thread claming its false? steel forks bend aluminum ones break at about the same harassesmnt
Old 09-06-2021, 07:57 PM
turbofanBoy's Avatar
the my car is non vtech can i still use an vtech one or has to be non vtech trans ?!
team 15
06-04-2007 12:56 PM
EF_LSVtec
03-02-2003 11:32 PM
rig9896
12-03-2002 09:25 AM
civicgsr93
05-14-2002 09:41 AM
Quick Reply: Best tranny for D16 turbo?
