best thing to do with a 99 ek ?
hey guys i got a 1999 civic ex with a d16y8 with only about 40k miles on it and i was wondering what every1 thought was the best thing to do to get more power. i have about 3-3500 to spend for everythin .. i want to make around 200-225whp so does every1 think a motor swap is in need or wat about turboing the d16y8 ? let me kno and if any1 has stuff for sale that i could use to accomplish this goal let me kno to thanks
I say boost it @ about 8-10psi, you'll run 230WHP all day on a good tune. That motor is too fresh to swap out just yet I think. I would work on the footwork (suspension/wheels/tires/brakes/etc.) before doing power though.
build a nice turbo kit and and the Y8 and you could pull a good 300whp out of that Single for around $3000 considering that you know how to work on your own car.
Re: (Frost7177)
swap in a b series, say around 2000, sell the D for 750-1000, got nearly half what you spent back already, so your at 2250, left, that would be enough to turbo the B and be up to around 300whp instead of 220whp.
Re: (Frickr)
Keep the y8 and Boost it... your not looking for mass power.. You just want to be quick.. Your saving your self a lot of time and money.. Plus u might have some change left to buy other lil things u might need in the process.. If u decide to swap in another motor. Just kno what your getting your self into..
Re: (blade0314)
well I found a whole kit for 1500
you will need to go obd1 meaning you will need a p28 or po6 ecu as well as obd2 to obd1 jumper harness
Turbo
Exhaust manifold
Intercooler piping
Intercooler
Wastegate
Blow off Valve
Injectors
Oil feed and return lines
Boost gauge
Boost Controller (optional)
Walbro fuel pump
Spark Plugs
If you look around in the forced induction for sale forum you can find lots of good brand used stuf for good deals.
Turbo
Exhaust manifold
Intercooler piping
Intercooler
Wastegate
Blow off Valve
Injectors
Boost gauge
Walbro fuel pump
Spark Plugs
Re: (blade0314)
all depends on what you use and who is tuning but I would use neptune for a tune and usually 300-600 for tune depending on tuner and dyno time.
If its your DD i think i would rather swap in a dependable B and bar it.
But i think you should build up some suspension first though.
car sounds clean! also your car is called an EJ8
chassis type - EJ
since yours is an EX its an EJ8
chassis type - EJ
MTracing
38
09-26-2011 02:46 PM
