Best place to get new axle.
I have a D16y7 and Im fixin to do a mini me...but my axle is throwing grease all over my wheel well/motor from both boots. The weird thing is that its not making any noise at all...none. I'm gonna replace it when doin the mini me I'm just looking for a good place that's cheap to get one...any help would be nice thanks
Re: Best place to get new axle.
raxles if you want something that lasts. I thought the extra $40 per side was well worth not having to deal with the autozone/napa reman units that are so hit and miss.
NAPA - get the used ones w/ lifetime warranty. If it goes out again just bring them the bad axle and they will give you a brand new one no charge, no questions. I'm on my third set in 5 years
if they are oem and not making noise just get new boots and repack them with grease, I would rather do that than go with any autoparts stores axles
Ok, please back up several opinions, I have installed many axles, both reman. and "new". Both from Autozone and NAPA and I cannot tell any differences in either or. What is wrong with autozone axles, new or used.
What makes NAPA's better? Most axles are replace due to busted boots. If caught in time, the joints are not damaged; i.e. grease is not all slung out. I would assume "new" axles from either are not made by the OEM manufacture , but I do not who that is. Most OEM parts are good , precision made stuff and I would suspect those parts are used in the reman. axles except boots, grease, clamps, nut and clips. Boots that don't break down due to wear will eventually breakdown due to ozone rot.
The only one I have replaced using warranty is because of a damaged boot......that I caused. Autozone said warranty covers that too.
if you go autozone DO NOT get the new ones. they make them with a slightly shorter shaft to save money so they are not as long as the oem. i have an eg with a b16 and the right side kept popping out of the diff. did some research and its kinda common. switched to remans and it hasnt happened since. i dont know about the other place but with vatozone go reman.
sirhavok
06-17-2007 02:12 PM
