best chemicals to clean with?
harsh solvents like break cleaner are just making me high and not cleaning and grime off the block...
Re: best chemicals to clean with?
engine degreaser foam
just use the gunk engine degreaser with the foaming action. trick is you gotta let it sit for a bit for it to work in good and then just go over some of the harder grease and grime by hand and repeat.works for me.
just remember to get the FOAM GUNK and not the other one. |
exactly what i needed to know. thank you both.
oh yeah forgot to mention that u need to do this with the engine cold or ur gonna be inhaling some nice fumes if u don't already know
Simple green, oven cleaner (it will get you wicked high so spray it and have lunch or something), carb cleaner/petroleum distallates/paint thinnner/acetone/xylene.
Engine degreaser.
simple green works good and doesn't smell too bad autozone sells purple power which works really good
Originally Posted by joelmatt89
(Post 37736399)
the engine is in pieces on my work bench. but that foam is making my transmission come to a high gloss. its quite amazing actually. but you really have to saturate it...
i will try simple green to, good idea. and ill grab some purple power, try that to. it will be a chemical test off. |
Originally Posted by ALLxMOTOR EG
(Post 37734972)
Engine degreaser.
simp green/brakleen
