best brakes for my 98 ex!
I wanna know what are the best brakes for my 98 2dr ex. i do go to the tracks and do a good bit of street racin...... any info would help.
Re: best brakes for my 98 ex! (98civicexsohc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98civicexsohc »</TD></TR><TR><TD CLASS="quote">I wanna know what are the best brakes for my 98 2dr ex. i do go to the tracks and do a good bit of street racin...... any info would help.</TD></TR></TABLE>
For a stock EX? Just go with what OEM recommends you don't need bigger brakes.
what tracks???? and street racing?? OMG!! haha you 17 or something??
EX brakes are perfect....just spend money on pads........look at Cobolt Vr4's(sp?) you'll end up spending 100 bucks on front pads but they are worth it if you go to "tracks' like you say........."better not mean the drag strip"
IMHO: good fluid, SS lines and good pads will make a VX stop on a dime!! yes with 9in brakes...
Re: best brakes for my 98 ex! (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue »</TD></TR><TR><TD CLASS="quote">you could do a gsr rear disc brake conversion</TD></TR></TABLE>
EX comes with disc's all around.
Re: best brakes for my 98 ex! (Happyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Happyman »</TD></TR><TR><TD CLASS="quote">EX comes with disc's all around.</TD></TR></TABLE>
96 and up never came with it, or if it did ive never seen one, i believe there were some 5th gen ex that came with rear disk and ABS.
1 Post
no they don't.6th gen only Si had rear discs.for the 5th gen,ABS equipped civics did.
to the original poster-get some good pads,new blank rotors and some good fluid;you'll have more than enough braking power.
Chris
Chris
since when??
99-00 si's do...... not EX as far as I know...
ONly EX that came with all disc is the 5th gen EX sedan.......
since when??
1 Post
Since when? Because either I am blind, or my EX, my Uncles EX, and my Friend's EX all different years starting with 96 and ending 2000 do not have rear Disk...
Re: best brakes for my 98 ex! (CooBlueDAB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CooBlueDAB »</TD></TR><TR><TD CLASS="quote">
Since when? Because either I am blind, or my EX, my Uncles EX, and my Friend's EX all different years starting with 96 and ending 2000 do not have rear Disk...</TD></TR></TABLE>
they do?!?!?! I wonder why my 98 ex has rear drums then
only the ABS ex's had rear disc buddy.
can you say OWNED!
can you say OWNED!
Re: best brakes for my 98 ex! (stockegsix)
Well then I didn't know 8 people would post ***** and correct me ^_^. I guess I figured since the del sol si came with rear discs(non-abs) same motor as ex that the ex would too.
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
I stopped reading after you said "street racin".
Risky Business
Re: best brakes for my 98 ex! (boostincoupe)
If you arent doing HPDE's every weekend, and the most stress you put on your brakes is mild autocross...i'd say a set of axxis ultimates and some ATE superblue fluid will be just fine
Re: best brakes for my 98 ex! (BauleyCivic)
by tracks i mean road racing................ not drag strip! i wanted to know if my stock brakes were good enough or if should go wit a completely new setup.
thanx for the feed back and i am 17 what about it!
if you haven't been on track yet, use your stock brakes.....then go from there...just get good pads ...
I made the mistake of not going out to the track stock...I went out with full suspension etc etc......
spock_rocker
07-30-2004 11:05 PM
whitemike1644
09-30-2003 11:29 PM
