EM1 with gsr swap having tranny issues
Old 07-05-2007, 02:35 PM
TEXASCRX's Avatar
Default EM1 with gsr swap having tranny issues
the car is a 99 si with a obd1 b18c1, the problem is shifting gears. when the car is off i can put the car into any gear at ease, but as soon as i turn it on its a bitch to put it into first or any other gear for that matter even reverse, and when ido get it in gear the whole car starts to shake real bad. what do you guys think it could be?
Old 07-05-2007, 03:30 PM
Donkey85's Avatar
Default Re: EM1 with gsr swap having tranny issues (TEXASCRX)
i didnt install the clutch disc upside down did you?
Old 07-05-2007, 04:10 PM
blackKready's Avatar
Default Re: EM1 with gsr swap having tranny issues (Donkey85)
the disc cant go in backwards , lol. it protrudes on one side , and is flush on the other , it only fits in the PP one way. but its definitely a clutch issue id say. the vibration your feeling is the clutch grabbing the flywheel even with the clutch in. have someone step on your clutch and hold it while you watch the fork on the tranny , see if it slowly goes back even with clutch held.
Old 07-05-2007, 04:39 PM
Donkey85's Avatar
Default Re: EM1 with gsr swap having tranny issues (blackKready)
i'm totally aware of that but, i have seen people do some stupid things
Old 07-09-2007, 06:13 AM
TEXASCRX's Avatar
ok here is the update, i havent messed with the cluth or flywheel, but ths weekend the car was driving pretty good i could shift it into any gear even downshift when i wanted to, but after a few hours of driving around i felt the shifter kinda sink in and the sameproblems as usual started happening, so with this said could the shift linkage be the reason for the malfunction
Old 07-09-2007, 06:18 AM
perseverance's Avatar
how does the clutch pedal feel? could be a bad cylinder? maybe bad slave or master. have u tried bleeding ur clutch? give us some description on the pedal feel.
Old 07-09-2007, 06:40 AM
gsr336's Avatar
i had this same problem with my gsr also... it comes and goes away... then after couple weeks it just stop running cause my pressure plate cracked in half.... how this happen? i dont know
Old 07-09-2007, 06:45 AM
speedooo's Avatar
Default Re: EM1 with gsr swap having tranny issues (gsr336)
had this problem, turns out my clutch master was bad and eating up fluid
Old 07-09-2007, 09:50 AM
TEXASCRX's Avatar
the cluth feels normal, the only thing that i can tell is off is the shifter
Old 07-09-2007, 11:18 AM
Default Re: (TEXASCRX)
get under it , have a look at the linkage , have someone shift it around while your looking for play. gotta be a linkage problem.
your pressure plate cracked most likely cause whoever had it apart last , overtightened it.
Dc295kid
12-19-2009 07:05 AM
slowdaintegra
12-21-2005 01:31 PM
RJL
11-28-2003 11:25 AM
phatintegra
03-20-2002 05:56 AM
eg_hybrid
10-06-2001 08:27 AM
Quick Reply: EM1 with gsr swap having tranny issues
