Best 300 upgrade
Best 300 upgrade
Have about 300 to put into the ride of my car, the guy i bought it from put some ruff springs in, dropped it 3 inches, i want to have it about 2.5 in dropped total. could i improve my situation, ne suggestions are greatly appreciated
A used nitous kit would be your best bet, just get a nice 50 shot, Zex Kit, people are always selling used kit for 200 to 1000 bucks, depending on the brand, that would give u the most hp for your money. You would need more to build the engine to take the nitous and not **** up to
Re: Best 300 upgrade (95civicdx)
clarify what your looking for and maybe we can help you. What setup is on it now and are you only trying to buy new springs or can the 300 be for anything? If your just looking for springs/coilovers, I would suggest the Groung Control setup. If your still running a 3 inch drop on stock shocks, Id suggest saving that 300 dollars, because they will blow in time. Best of luck to you!
i'm looking to make my ride smooter, and i'm pretty sure it has stock shocks, how much to replace shocks and put in ground control?
Depends...somewhere around 800 dollars if you go with Koni Yellows...Id suggest KYB AGXs....with GCs...a little cheaper! Well..on second thought, if you don't want the adjustability or are not planning on road racing this car...go with some lower end shocks (Koni Blues or Illuminas) and just a slightly lower drop!
Tong.Y
Suspension & Brakes
61
12-23-2010 11:22 AM
