Motor mount or Axle ?
Old 03-18-2012, 10:54 AM
vyrus's Avatar
Icon3 Motor mount or Axle ?
Ok guys i'm facing this weird issue with the car ever since i installed new clutch. Engine (or car ?) bounces like hell when i lift the clutch and press accelerator (parking etc). It's quite severe actually. Entire dashboard and all parts shake! once the car is running, i can't feel anything. But whenever i downshift or so, it vibrates a lot. Also, sometimes if i try to launch i feel like a grinding noise or something from the passenger side, which leads me to believe theres something to do with the axles aswell.
So what is it ? Axle or Mount (rear mount?) or maybe both ?
Old 03-18-2012, 10:59 AM
The Grumpiest
grumblemarc's Avatar
Default Re: Motor mount or Axle ?
Are you sitting there just wondering or have you AT LEAST inspected the motor mounts? I don't see how it could be that all of a sudden but you should at least do a visual inspection.
Old 03-18-2012, 11:06 AM
vyrus's Avatar
Can't take a look at the rear mount have only seen the driver side and passenger side mounts.
Old 03-18-2012, 11:09 AM
The Grumpiest
You might get a clunking but not a vibration if the mounts were busted. And when they go they usually explode that gunk that they're filled with all over the place.It seems obvious to me you have issues with your axles. ESPECIALLY if you just installed a new clutch.
Old 03-18-2012, 11:30 AM
vyrus's Avatar
Yes it's clunking. Couldn't think of the word lol hence i wrote vibration. It's like engine literally stomps the car. Also, i think i have seen some weird fluid-like **** all over the bar at the back. I guess that means my rear mounts effed ?
Old 03-18-2012, 12:10 PM
ehrkeith's Avatar
CV boot could be torn shooting grease everywhere explaining all the gunk on the firewall, but as far as the whole car shaking im not 100 percent.
Do a visual inspection on your mounts like he said, and check your cv boots, and replace if you have the funds its about 120 for two new axles at the store, or I have some for sale lol.
Old 03-18-2012, 12:17 PM
akelly17's Avatar
Its your mounts dude, especially if you installed a "more than stock" clutch, it can chatter like crazy if you have bad mounts, even if they aren't busted but just super worn it can still happen. I have had some pretty **** axles before and they never caused that to happen but bad motor mounts will do it every time without a doubt. make sure that the mounts are also all bolted down tightly as you just removed the tranny side and t bracket mount to replace your clutch, ive had them come loose on me after doing a clutch before.
Old 03-18-2012, 12:22 PM
The Grumpiest
Mounts cause grinding noises? If so that would be a first for me.
Old 03-18-2012, 12:27 PM
vyrus's Avatar
i thought by clunking you meant like hitting or stomping. idk my vocabulary's weak lol and english ain't my first language . But yeah, its definitely shaking the hell outta the car.
Old 03-18-2012, 12:28 PM
vyrus's Avatar
will most definitely check that tomorrow. might even be loose nuts, who knows!
Old 03-18-2012, 01:57 PM
akelly17's Avatar
i was referring to the clunking, not the grinding noises.
Old 03-18-2012, 10:00 PM
vyrus's Avatar
anymore suggestions ?
Civicfanatic_09
10-06-2009 02:45 PM
Dirtyb16
01-24-2009 01:56 PM
Rocks
06-30-2004 07:47 AM
sunlei
03-21-2004 06:10 PM
driftt
07-15-2003 04:03 PM
Quick Reply: Motor mount or Axle ?
