Benefit of JDM TypeR rear LCA's?
I just picked up a pair or type r rear lca's with springs/struts. what would be the benefit of having them over my stock ones besides being able to put on itr sways?
Re: Benefit of JDM TypeR rear LCA's? (92CXHB)
Well on the LCA's the benefits would be you can now use a rear sway bar. And as for the Springs besides them being stiffer the regular SI's or GSR's I would say that they are 1 inch lower then Stock GSR springs and the shocks are made by Bilstein.
[Modified by Extreme_Hybrid_Hatch, 9:32 PM 11/24/2002]
only benifit i can see is
-holes for mounting rear sway
-boxed lca might be slightly more rigid
-main thing is you can use jdm coilovers
Re: Benefit of JDM TypeR rear LCA's? (G-Prime)
No it would not be has a ***, but I am not sure if you can use the stock springs they are too wide for the Type R rear LCA's I think.
1) itr sways
2) itr rear shocks (and springs if you want)
3) run some fancy jdm coilovers
Re: Benefit of JDM TypeR rear LCA's? (joseph h)
i picked them up with gsr front lca's, jdm typer rear lca's, f/r gsr sways and gsr strut tie bar for 220.
would it benefit it me to get the typer front lca's? is there a difference between the gsr's and type r's?
Steve91
12
03-11-2003 05:58 PM
