bellhousing access hole?!?! where?? ASAP
Old 01-28-2004, 04:26 PM
mike93eh
Guest
Posts: n/a
Default bellhousing access hole?!?! where?? ASAP
ok i tried asking this in the teg section but im getting no replies..
i was wondering where to the bellhousing access hole is on a b18b1 automatic? i need to find TDC. im changing timing belt and water pump
please help fast!! pics would be good also...thank you.
Old 01-28-2004, 04:52 PM
mike93eh
Guest
Posts: n/a
no one has an ls engine?!
Old 01-28-2004, 04:53 PM
Team 4R's Avatar
Default Re: (mike93eh)
tdc? why dont you just line up the crank pulley?
EDIT: oh, it's automatic..... i wonder if that matters.........
Old 01-28-2004, 04:56 PM
mike93eh
Guest
Posts: n/a
Default Re: (Team 4R)
i dont see no markings on the crank pulley. but i still need to find the access hole for toher things..im changing the timing belt and water pump.
Old 01-28-2004, 05:19 PM
dantastic's Avatar
umm. the timing belt is on the other (driver's) side of the engine... i'm pretty sure there's no access hole for the bellhousing/torque converter/flex plate
Old 01-28-2004, 05:29 PM
mike93eh
Guest
Posts: n/a
Default Re: (dantastic)
well crap i dont know where the marks are to set it at TDC..
and wheres the timing marks, i feel so dumb right now. i can easily find them on any other engine,. but damn..
how do i get the crank pulley off without it turnin?
Old 01-28-2004, 05:32 PM
dantastic's Avatar
http://www.c-speedracing.com/h...t.php
with the car in park, the tranny shouldnt move, you the crank bolt should come off with regular tools
Old 01-28-2004, 05:40 PM
ultimatehonda's Avatar
Default Re: bellhousing access hole?!?! where?? ASAP (mike93eh)
Dude to find TDC you need to take the valve cover off and look at the cam gears...they have lil arrows and you align them facing up i believe to get piston number 1 to TDC
Old 01-28-2004, 05:42 PM
mike93eh
Guest
Posts: n/a
thank you sir, for the link also
Old 01-28-2004, 05:43 PM
dogfood's Avatar
I went through the hassle of the crank pulley. They'll try to tell you that a strap wrench and a breaker bar will get it off in a book, thats BS. Impact the hell out of it. It'll come right off, no turning. If the crank pulley doesn't have a mark on it for top dead center(it should though), get the crank pulley off and check the gear on the crank shaft, maybe that will have a mark on it to line it up. Make sure that number one is at tdc and that number four is not at tdc. Check the distributor to make sure it's ointing at number one, just a tip. Good luck, timing belts are a pain in the ****.
Old 01-28-2004, 09:01 PM
mike93eh
Guest
Posts: n/a
Default Re: bellhousing access hole?!?! where?? ASAP (dogfood)
i hope you guys dont think im stupid. really long day today and my brain was working right. i did infact overlook the timing marks on the crank pully. i got the timing belt and water pump on tonight and everything is running good
i have a helms for my civic but not my teg. i shoved a screwdriver in the access hole to get the crank pully off. ive done everything you can imagine on imports and domestics, but this was my first time working on this motor. i feel stupid for posting this haha.
suje
14
02-22-2012 04:19 PM
99blackdc2
07-28-2006 07:23 PM
TorquelessB16
05-24-2006 12:33 PM
mike93eh
01-28-2004 09:14 PM
Jonathan_ED3
04-12-2003 02:55 PM
Quick Reply: bellhousing access hole?!?! where?? ASAP
