beefing up tranny?
Old 07-31-2004, 05:15 PM
97dxnut's Avatar
Default beefing up tranny?
I know there are numorous wsy of improving the strength of the engine. Pistons, rods, sleeves, machining, etc. But are there any ways of improving the strength of the tranny? Maybe something that will reduce the damage that grinding while shifting will do? Thanks
97dxnut is offline
Old 07-31-2004, 05:16 PM
thrty8street's Avatar
Default Re: beefing up tranny? (97dxnut)
maybe some GM syncromesh
thrty8street is offline
Old 07-31-2004, 05:21 PM
97dxnut's Avatar
Default Re: beefing up tranny? (thrty8street)
Thanks for the quick reply. I know about synchromesh, I was looking for something more substantial.
97dxnut is offline
Old 07-31-2004, 06:26 PM
ditch your short shifter and learn how to shift
but seriously you can have get a tranny built with carbon syncros and have the gears cyrotreated and shot peened. or you could buy 2, 3, maybe 4 or 5 replacement trannies instead. (i don't know how much it costs but i do know it isn't cheap)
also if you're driving around the street with a stock motor and a something like a 6 puck clutch, maybe change it out for something less aggressive that could still do the job just fine.
i've been driving with a 3rd gear grind for months now. i just double clutch to 3rd to bypass the syncro and it's holding up great. (knock on wood )
The Internet Tough Guy is offline
Old 07-31-2004, 06:40 PM
Moderator
chad's Avatar
well...if honda trannys can stand up to the 500hp beast.....i really don't think you are gonna have a problem
chad is offline
Old 07-31-2004, 06:41 PM
TeamNextGenChris's Avatar
best way to reduce damage from grinding while shifting is to learn how to shift.
for the most part,Honda trannys are able to handle a lot of power-more than 99% of street cars will produce.there are plenty of very fast Honda drag cars using stock trannys with the exception of aftermarket LSDs.
Chris
TeamNextGenChris is offline
Old 07-31-2004, 06:48 PM
Default Re: beefing up tranny? (TeamNextGenChris)
Honda trannys are sickly strong, you don't have to do much to beef em up. PERSONALLY I found the stock shifter in my SI to be very rubbery and vague feeling, so I went with a skunk2 short shifter, paired up with some GM synchromesh and a quaife and it's a great running setup.
b16sedan is offline
muddmonky
Transmission & Drivetrain
02-25-2013 08:31 AM
hondateg10
07-22-2008 03:54 AM
ajrees25
10
10-10-2005 04:31 PM
GWInquisitor14
10-15-2004 10:06 AM
Jeff33S
01-15-2002 04:30 PM
Quick Reply: beefing up tranny?
  • Ask a Question
Question Title:
Description:
