Beaks Kit on EK - Installed Photos
Finally got around to taking pictures of the beaks kits installed. Photos from a few different angles so you can get the full affect.
You will notice the thickness of the beaks plate. This draws the ITR sway bar away from the subframe so that the endlinks are A LOT closer to verticle then if you didn't have them(ie honda-hybrid how-to). This makes the sway work better.
Re: Beaks Kit on EK - Installed Photos (WishIHadANiceCarToo)
Wil at Beaks Products sent me the beaks kit, the ITR sway bar, prothane bushings/brackets and SI endlinks, ALL BRAND NEW for $250 to my door. This was before he officially offered it as a full kit, so I his official pricing may be more or less then what I payed.
Re: Beaks Kit on EK - Installed Photos (Spade)
The LCA is a TDM (Tawainese Domestic Market) piece. They are made by SRR. Aluminum. Not any lighter then stock, but much nicer and stiffer.
I got the LCA's from "vancolee" sp? here on honda-tech. $195 to my door in a few days!
[Modified by tonyxcom, 11:16 PM 4/4/2002]
Re: Beaks Kit on EK - Installed Photos (slowerthanu)
OG triple OG
Re: Beaks Kit on EK - Installed Photos (tonyxcom)
that **** is dope as ****!!!! im jockin . since im waitin for the warrenty to expire on my engine before i destroy it and drop an SIR2 motor in , im buildin supsension , imma get that **** tonite , i like that **** , does SCC have a website?
peace ,mark
peace ,mark
Re: Beaks Kit on EK - Installed Photos (CheezeFrog)
Are those Integra rear calipers I see on the back? How'd you get them so shiney?
Here is a tip.
Use a stiff wire brush when the calipers are dry at first. Scrub to break up all the built on crud and get as much of it off as you can. Then spray with brake cleaner. Then repeat the process until you get it as clean as you can.
Ohhhh, pretty colors....
Nice combo with the SRR lcas, red KYB's and zinc/gold brackets, red bushings etc...
Glad to see the beaks kit at work. Purchased a sway bar for my "EG" my freakin subframe is bent and the length is somehow messed up just enough to make the measurements across the vehicle all worng back there Time to sell this civic, can't believe I was got by the previous owner, had a clean title history to, freakin front strong bar was bent to hell, rad. support just ever so slightly misalighned and now this... Oh well live and learn.
Re: Beaks Kit on EK - Installed Photos (dwnthehatch)
Beaks EK kit:
Parts Included
Beaks Products SRK-EK
Acura Integra Type-R rear stabilizer, 22mm dia.
Prothane anti-sway bar bushing and bracket kit
Installation Instructions
Order Info
Price: $160.00 USD plus $15.00 shipping charge
Shipping: UPS Ground
Payment Method: PayPal, money order, or cashier's check
Parts Included
Order Info
Re: Beaks Kit on EK - Installed Photos (acura_typer)
"I got the full suspension techniques front and rear tuned kit for $224 shipped to my door from Summit Racing"
If I wanted to tear my subframe, I would have got that too. And I have a CTR/SI front swaybar setup. Far superior to the ST setup.
Yes that is teflon tape. Two wraps around the bar, absolutely no grease, not a sqeek from the bar yet. And it stays.
