Battery light flashing
some reason the battery light started flashing last night when i turned a corner real hard last night. i checked the connections they look fine. pos looks dirty and one of my belts is cracked. though im not sure.. what do u guys think
Re: Battery light flashing (pane93civhb)
check your alt.
Re: Battery light flashing (Geeky_Gambit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Geeky_Gambit »</TD></TR><TR><TD CLASS="quote">check your alt.</TD></TR></TABLE>
Yeah when my alt started going out the battery light would be on till about 3000 rpm and then shut of but the closer I got to 3000 the light would start flashing. Most likely an early warning sign of a failing alt. |
i would chk your battery first. if it fails the load test then the battery is bad then chk the alternator because that can cause your batterry to go bad. you probbably have abad alternator any way. minimum you will be looking at a battery and an alternator.
