battery / ignition problem
odd thing happened to me yesterday.
went to the car to start it and no power whatsoever when i try to turn the motor.
No acc/ no dome/ no lights.
But when i try to remote start it with my clifford it turns.
I find that my battery has drained and need to jumped to get going.
So I jump it run and the alternator manages to charge enough for running without another jump.
Here is where it gets odd/weird, i turn off the car and take out the key. it turns EVERYTHING OFF. i lose my dome and everything and no power when i put the key in the ignition for accessory. is it because the battery is so low? but when i use the remote start it has enough juice to run the alarm brain?
went to kragen and had a load test and battery test. they things are running normal.
so my setup is an amp running to battery, alarm. so any ideas.
Thanks any advice would help now.
Re: (ocJDM4dr)
if that is blown... should the engine run once the car is jumped? and if i take out the battery the car is still running?? or does that mean the altenator is compeltely done
Tyler_Durden
06-19-2003 09:55 AM
