battery cables
Old 05-10-2006, 03:52 PM
caliek4's Avatar
Default battery cables
ok so after countless times of removing my battery cables, they wont stay on. i mean that i can remove them with out unscrewing anything. i bought new battery terminals and was about to change them. i was just wondering is it better to buy new cables also or just use the existing ones? how easy is it to replace the battery terminals with the existing wires?
p.s. it a 2000 ex
Old 05-10-2006, 04:34 PM
sohcvtec1995's Avatar
just change the wires. Great time to upgrade,to gold terminals and thicker wire or even relocate to trunk.
Old 05-10-2006, 06:01 PM
caliek4's Avatar
Default Re: (sohcvtec1995)
bump
Old 05-10-2006, 06:34 PM
old man neri's Avatar
Default Re: (caliek4)
Depends what is the condition of the old cables. If you have tools to put the connectors on then sure. However if you don't have the right tools to do it it might just be easier to just get new cables, they shouldn't be that expensive.
Old 05-12-2006, 03:19 PM
caliek4's Avatar
Default Re: (old man neri)
any other thoughts?? bump
Old 05-12-2006, 06:42 PM
JDMegCoupe's Avatar
well they have the.....don't know what's the correct name but like a little flat sponge wipe almost thingy some cut up fabric that you can buy from the auto store and put on top of the battery connector and then place your cables it'll make it more tight and not come loose unless you just have a bad cable with bad bolts which you then need a new one
pityocamptes
22
12-19-2013 10:55 AM
ronniedi
09-26-2010 08:56 PM
Re3irth
23
07-15-2008 06:12 PM
boosted civic 2k6
12-04-2005 01:30 PM
DieMaster
09-10-2004 04:20 AM
Quick Reply: battery cables
