A/C Problem
Old 08-24-2010, 04:17 AM
Bartman201's Avatar
Icon2 A/C Problem
i just got a 95 Dx hatchback. i turn on the A/C and all i get is hot air. i check the fuses and they are all good. the condenser fan runs but the compressor clutch is not turning i check it by moving it with my hand and it does turn smoothly. Can anyone help thanks.
Old 08-24-2010, 05:39 AM
Former User's Avatar
Default Re: A/C Problem
If refrigerant pressure on the high side is too high or low, the A/C pressure switch in the receiver/dryer will prevent the compressor clutch from engaging.
When you push the A/C button on, does the engine idle speed increase?
If you switch the compressor clutch relay and condenser fan relay, does the condenser fan now fail to run but the compressor clutch now engages?
Old 08-24-2010, 09:06 AM
Bartman201's Avatar
When I hit the a/c button the idle speed changes but not much. ill check switching the relays tonight when I get off work. Thanks for your help
Old 08-24-2010, 01:00 PM
If the idle speed bumps up when the A/C button is pushed, it tells you that the ECU receives the "on" signal from the heater control panel and that the A/C pressure switch is closed (=good). This means that the possibilities are a bad clutch relay, a bad thermal protector on the compressor, or a bad or improperly gapped compressor clutch. The results of swapping the relays should begin to limit the field further.
Old 08-24-2010, 03:57 PM
Bartman201's Avatar
where is the clutch relay located?
Old 08-24-2010, 05:57 PM
weavertime1's Avatar
Check the line to see if there is any refrigerant in it. Just take off the cap and press down on the valve to see if any is released. this should let you know if any is in there. It sounds as if you have no refrigerant.
Old 08-24-2010, 06:04 PM
Old 08-25-2010, 08:47 AM
Bartman201's Avatar
Yes it has but it looks like it had low pressure.
homermeza
04-18-2017 06:51 AM
BSDMotorSports
07-28-2013 04:12 PM
jdwheat1
11-24-2012 11:03 AM
Arsenal
08-22-2004 03:55 PM
freddy_hung
11
09-21-2003 07:32 AM
Quick Reply: A/C Problem
