balljoint and support bar thing help
long story short. i need to get my trans out so i've been taking apart my car and i can just about drop the tranny except for this
somehow the other side basically just fell out w/ a little pry from a screwdriver
so i thought...might as well get a fork and use that....nope
bent
mangled on one side
mangled on the other side
and then a stress crack down the center
so please....i already destroyed the boot trying to get it seperated and i don't want to replace the whole ball joint if i don't have to so please someone give me an idea on how to do it. i've trying crowbar, the fork that broke, heated it w/ mapp gas, and used a big *** hammer and still nothing. someone please tell me you know a trick or something to get this off...like i said the other side took literally 5mintues or less.
bent
mangled on one side
Re: balljoint and support bar thing help (Cypher0117)
It should have came off with the fork, keep trying with the fork keep hitting the end of it should come out
Re: balljoint and support bar thing help (NA EG6)
jesus...i know how you feel, the only way i got mine out was to use this puller thing the dealer has (my bro is a tech @ honda) visious little thing. anyway, the way i USUALLY get mine out is to bash that little **** (seen in pic #1) with a hammer really hard.
ninja edit. you need a new balljoint now :S
ninja edit #2, you dont have to seperate the balljoint to get the trans out...its a little in the way but not by that much...
Re: balljoint and support bar thing help (Sleepy_Red_hatch)
i was also using a 3 ton gear puller trying to get that off...but that didn't seem to work. by the time there was a lot of pressure on it the thing just popped off. hit my friend in the hand and he has a nice inch welt so i know there was pressure but it wasn't moving. I figured that i would need a new balljoint seeing as to what i did to this one. I can get those at a Honda dealer im assuming or a napa. about how much do they run? and do i need to separate the axle from the hub to replace the ball joint?
HT White Ops
Jump on that ****. That's what we had to do for my girlfriend's car when we swapped her clutch. I ended up smashing my thigh on the fender too, huge bruise. But it came loose.
Re: (Cypher0117)
ive had this happen to me alot, for some reason always the drivers side sticks? I have a lift, and with the car on the lift, i'll take a 4x6 and floor jack, and lower the car a bit and lift the suspension with the 4x6 and jack, take the pressure off the ball joint a bit. If you can do anything like that if your on the ground or what not, thats a help. looks like a cheapo fork too as for replacing the ball joint, it has to be pressed in, and im sure you can tell by the shape of the knuckle, you need a special tool to get in there to press it out/in. you'll have to pull the whole knuckle off, and take it to someone who can press it. so get the axel out, disconect the tie rod end, upper and lower ball joint, and all the break stuff. you've allready killed the lower ball joint, just try to get some pressure off of it, and beat the hell out of it with a new fork just be more carefull with the upper ball joint, theres no replacing that, have to get the whole upper control arm at that point.
Re: (BogusMalone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BogusMalone »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=887859
check this link and watch the video.</TD></TR></TABLE>
yes... the magic trick!!! Why people are still using pickle forks or buying that ball joint tool is beyond me...
Based on the damage you've done to the pickle fork I'd say you'll need a new ball joint... $30-50
You'll get to take out some frustration on the damn thing...
remove caliper, disconnect endlink, remove knuckle... and for stress relief, take a BFH and pound the balljoint out (watch ur fingers). Getting the new one in can be more tricky... I've seen people press them in, pound them in and air hammer them in... take your pick...
Re: (miahmouse)
WOW....a $5 dollar ball joint seperator from Vatozone is definitely your friend.
Sometimes called a pitman arm also.........
U were pickle fork owned!!
Re: (BogusMalone)
BogusMalone thank you for the link...worked like a charm. now that its off i can just about drop the tranny. do you think i need a whole new ball joint or can i just buy a boot and fillit w/ greese?
Replacing the ball joint after you get it removed is not very hard at all.
Read:
https://honda-tech.com/zerothread?id=1567042
The nice thing about the tool rental is that it ends up being free.
m-
Read:
m-
type_eg_r
11-30-2006 03:15 PM
Quetzolcotl
05-09-2006 06:04 PM
*Boostwerks*
34
05-07-2006 10:29 PM
94integrablur
06-25-2002 02:28 PM
