Ball joint problem
Ball joint problem
Ok I got my brakes in today. But the driver side font lower ball joint doesn't seem centered. It's crooked slightly to one side. The other side seems perfectly centered. Does anyone know if thuis is fine. Also can the dx front lower ball joint be swaped over to the new SI front arm. Are they the same. Thanks.
When I said crooked I mean it's not centered. When I move it to the center it looks like it's shifted to one side. Once I let go it's angled to one side again. Do you think it's bent.
Re: (wdskuk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wdskuk »</TD></TR><TR><TD CLASS="quote"> Do you think it's bent. </TD></TR></TABLE>
id have to see it to know. anyway you can get pics of this?
Re: (wdskuk)
hey Mustar is that you pounding out a ball joint? anything special you have to go just put them out from the bottom up? I was worried I would have to press them out but if you did it with that I can take them out no problem. does the new one go in easy that way or what it the trick?
I just put gsr suspension in my hatch and my ball joint threads were fucked from being pouned I just called the mac guy and got the right size die and cleaned out those threads.... I would replace it if you can if not it still should work the way it is just line it up and get the nut on there... USE THE KOTTER PIN
how much are new ball joints???
Re: (92HatchHybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92HatchHybrid »</TD></TR><TR><TD CLASS="quote">hey maztur is that you pounding out a ball joint? anything special you have to go just put them out from the bottom up? I was worried I would have to press them out but if you did it with that I can take them out no problem. does the new one go in easy that way or what it the trick?
how much are new ball joints???</TD></TR></TABLE>
Yes, you can pound the old one out and the new one in. When pounding the new one in, use a little grease and a smaller hammer tapping slowly.
Re: (wdskuk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wdskuk »</TD></TR><TR><TD CLASS="quote">I just checked the threads and they seem a little messed up. I can't really turn the nut onto the threads without turning the joint</TD></TR></TABLE>
I've been through that before too. Sometimes the thread is just a LITTLE flattened but it can be fixed. Take a SUPER sharp knife and cut at the threads while checking periodically with the nut to see how and if it'll go on.
