BAFFLE PLATE?
BAFFLE PLATE?
The baffle plate , what does it do and what's it for?
my friend changed his oil pan and we notice it didn't have one on his gsr block so i wanna know what its there for i know its gotta be there for a reason..
its called a "windage tray" actually
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Windage
Windage is the flow of air within the crankcase. Each time a piston comes down in the piston bore the air under it is pushed into the crank area and each time the piston goes up the air is pulled in behind it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Windage trays
A windage tray keeps the windage around the crank from the oil in the sump area. It should allow the oil coming off the crank to easily enter the sump without the windage affecting the oil already in the sump. A good windage tray should also keep the oil in the sump from getting into the rotating assembly when the action of the vehicle is in motion.</TD></TR></TABLE>
this is what i found on wikipedia lol
baffle (plural baffles)
A device used to restrain or regulate, e.g. sound, light, gas, or a fluid.
Tanker trucks use baffles to keep the fluids in them from sloshing around inside.
got this
http://www.nengun.com/tomei/oil-baffle-plate
after researching i got my anwers just posting to help other so dont flame by saying "you should've done that before you posted"
got this
Re: (hatch-E-vanish)
windage trays keep excess oil from encoutering the crank, despite what u might think oil splashing onto the crank will not be a benefit of more lubrication, the crank internally lubricates itself just fine, oil contacting the crank will apply resistance. kinda like its easier to run in air as opposed to running in water. same idea here.
now as too why your buddy's gsr doesnt have one, cant tell u why I personally do not know if they come with one from factory or not.
Re: (seabass10369)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seabass10369 »</TD></TR><TR><TD CLASS="quote">windage trays keep excess oil from encoutering the crank, despite what u might think oil splashing onto the crank will not be a benefit of more lubrication, the crank internally lubricates itself just fine, oil contacting the crank will apply resistance. kinda like its easier to run in air as opposed to running in water. same idea here.
now as too why your buddy's gsr doesnt have one, cant tell u why I personally do not know if they come with one from factory or not.</TD></TR></TABLE>
im 100% sure they do do come with them i read it on helms, i just didn't know what it was for
been there done that
Re: (primeredsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by primeredsol »</TD></TR><TR><TD CLASS="quote">the baffle plate also keeps from starving the oil pump of oil during cornering. but thats only in multiple hard cornering roads and such.</TD></TR></TABLE>
you're thinking of baffles in the oil pan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch-E-vanish »</TD></TR><TR><TD CLASS="quote">baffle in the oil pan is what im talking about.. </TD></TR></TABLE>
so is that what you've been talking about this whole time? if so b series oil pans do not have oil pan baffles.
Apocalypse
10-16-2002 04:29 PM
