a bad jdm d15b??
a bad jdm d15b??
i drive a 97 ek hatch and have a obd1 jdm d15b vtec swap. right now its throwin a O2 sensor CEL and it has trouble idling sometimes. my motor feels fine for daily drive but it doesnt pull anywhere near like when i first swapped it in. i cant even take EX coupes now. but im thinkin if its even worth fixing this motor or should i jus let it be and save up for a new motor?d16y8?
Re: a bad jdm d15b?? (ph0shizzle)
What ecu are you running? If your running a p2p then its looking for the 2nd o2 sensor. If your running an obd1 ecu then try replacing your o2 sensor and clearing your codes.
Re: a bad jdm d15b?? (Luserkid)
i do have one.. but it keeps on throwin this cel after every like 3 months.. if i replace it, its goin be like my 4th time replacin it.. i put more money into fixin this motor than it costs.. so i was jus wonderin if its still worth it? or should i might as well save up for a new motor
Re: a bad jdm d15b?? (hondamark35)
well i have a jumper harness which is supposd to make my ecu think its pluggd in or somethin like that.. but not havin one will make my o2 sensor bad?
yeah not having one can damage it. but if you have a chipped ecu. then it should have been chipped not to read o2. since it's intermittently that your 02 is throwing codes you might want to check the circuit for any opens short to grounds etc.
Manolo
23
08-16-2007 07:00 AM
ph0shizzle
08-26-2006 02:49 PM
Team 4R
02-03-2004 04:45 AM
