Bad fuse console...
Bad fuse console...
Tailight fuse always burning out as soon as i turn on my corners
i tried putting different fuses in but they keep getting blown out....
where are the grounding wires??
Re: Bad fuse console... (hafaadaiteg)
you have a short in that circuit... replacing the blown fuse with bigger fuses is NOT the right way to fix it. you are just going to make problems worse by going about it that way. check all your wiring and find where your short is.
problem fixed.
problem fixed.
