Bad ECU? 95 d16z6
Bad ECU? 95 d16z6
Ok so i've done my research on here and i'm just out of ideas. I have a 95 d16z6 with a bunch of goodies and a tuned ecu. I've been having a problem throwing a code 6, which is a coolent temp sensor, its been replaced still no luck, then i replaced the wiring on it goin all the way to the pigtail on the ecu. Still throwing a code. Now another problem is the VSS. Done the exact same thing, replaced vss, made sure it was tightened and seated properly and completly rewired it. I know my wirings right. The vss works when it wants then jumps erracticly when i get higher in the rpms. Now that wouldn't be a big deal if the ECU wasn't tuned cause once it hits a certain rpms the drag launch thats been tuned into the ecu kicks in no matter what gear i'm in and i'm stuck at around 3.5k rpms. Dangerous. Do you think its the ecu? I don't know anyone that has one that will let me borrow it to see, but i don't want to buy a new one and have the same problems.
slammedz6ef
03-04-2008 11:13 PM
cnyej1
07-13-2004 07:22 PM
Eibach95Civic
09-13-2003 03:44 PM
