B20B swap 94 honda civic misfire (solved)
Hello again. Last thread got closed before I could even explain anything.
Installed OEM injectors. Am still running OEM fpr and for some reason fuel pressure is at 80 psi. Before I installed 550cc injectors fuel pressure was at 38-40. I have a gauge on fuel filter. And I still have backfire problem with full throttle. No fire but a good boom. Ecu fuse blow 3 times. I checked all wires on fuse box and under hood. could not find a short. I have my injectors connected correct so I am confused. Thanks for any help. no engine light
Re: B20B swap 94 honda civic misfire.
Just replace return line. Also I bought a aftermarket fpr fully adjustable just has not gotten here yet. Tracking num says will get here today. Will see what happens. Thanks
Did a amp test on ecu fuse. In engine bay fuse box. Removed fuse conected test leads were fuse goes got a reading of 0.49 amps. Graphs says ecu fuse is 15amp so I should have over 10 amps there right? And from my understanding low amps- high resistance. High amps- low resistance.
found big news today. Fuel started leaking from banjo fitting. on fuel rail side. removed and replaced copper washers. still leaked. so I removed again and inspected fuel rail. noticed no hole for banjo fitting..... face palm, I had bought new fuel rail with out thinking. Jus bought adapters and gonna install 6an fittings with steel hose. will post an update when they get here.
Sorry took awhile. Problem with fuel pressure was with the fuel rail. Bought a new fuel rail installed AN fittings, pressure back to 40. Found short replaced wire and pins. Car is running strong. Thanks for all the help.
CodyGt3076r
11-14-2012 10:30 AM
ITRfaithful
11-02-2003 06:15 PM
