Stock 98 e.x crank, no start
Old 01-17-2023, 06:35 PM
D3vab's Avatar
Default Stock 98 e.x crank, no start
Hi guys I have a 98 e.x coupe with a d16y8 and about a month ago my car shut off on me while I was on the way home and no longer will start the timing belt is fine and so is the timing we checked the distributor and it looks fine and we tried starting spray but it wont fire up at all any ideas? Im stumped right now and it was my daily driver
Old 01-17-2023, 08:25 PM
JRCivic1's Avatar
Default Re: Stock 98 e.x crank, no start
For an ICE to run, you need three things: Air, Fuel, and Spark. Air... must include the engine being in proper mechanical time. Fuel... Check your spark plugs after attempting to start a few times and see if they are wet. Spark... pull a spark plug out of the valve cover, remove the matching spark plug, insert it into the end of the plug wire and place the threads of the plug on something metal on the engine like a valve cover bolt. Crank. Do you have bright blue spark jumping across the plug gap ?
IF the answer to all three of these questions is yes, then you are missing something. Once you know what you are missing, report back here for further instruction.
Gmijangos
12-19-2016 03:32 AM
johan140
07-23-2015 12:59 AM
rustanghunter
11-13-2010 01:23 PM
EG6_GSR
11-20-2006 10:05 PM
Quick Reply: Stock 98 e.x crank, no start
