B20 swap tilt in me ek hatch please please help!.
Ok so I just got done doing my swap this is my first time doing it and yes I'm a noob at this and I know you guys on here are extremely good at all this..with that being said I bought the 99-00 si rear bracket that fits fine I also bought innovative mounts so the driver side has that bracket and on the passenger side where it holds the tranny I te-used the d16 bracket..I know that in the picture it shows the stock mount on the passenger side but that's because I took the innovative mount out to see if I put the stock in there would've fixed the problem but it didn't..I've been researching all day the only one I come across post wise is a b18 swap on here that the guy had the exact issue but in his case the post mount bolted to the block at the timing belt is three holes mine is two holes..so do I need to get an ls tranny bracket for it to drop on the passenger side or does the driver side need to b changed.all advice will b greatly appreciated that's all that's holding me up thank you in advance guys!. Ps if the pictures don't show I will post them again or try to lol
Re: B20 swap tilt in me ek hatch please please help!.
Would this be the bracket I need on the passenger side so it will sit lower?.instead of using the D series bracket?.
Crazy Honda Guy
If you were using 99-00 driver side mount, and post mount, this engine would fit perfect! I had one, was one of my all time favourite cars.....
-Intl Steve Krew
You need a 99-00 Si 2 bolt post bracket, the b20 post bracket is not correct.
Innovative makes their own version or you can buy a factory one.
