b20 swap into 93 coupe...
After searching, and searching and searching I still have yet to find ANYTHING about a b20 swap into this gen civic... Ya, theres some info out there but not to clear...
First off, 5th gen civics have a hydro tranny correct?
Second, I have a complete b20 that I took out of my 90 Integra, If I were to get the hasport mount kit would everything be a bolt in job? Use teg axels, linkage, harness, ECU? Or would I have to use different axels and linkage b/c of the hydro tranny? Im not familular with the hydro trannies at all so any help is appreciated...
Third, If you can send me ANY HELPFUL links for this kind of info it would be greatly appreciated...
I've found many sites for wiring and such but nothing about actual parts to be used...
TIA and please dont get on my *** for searching!
Dev
Dev
Re: b20 swap into 93 coupe... (Dev90gs)
Yes, 5th gens have a hydro tranny.
Swapping the B20 is exactly the same as any other B series swap.
http://www.crvtec.com ? I wonder if it is still around.
http://www.hasport.com
Re: b20 swap into 93 coupe... (Spade)
Thanks Spade for your reply!
crvtec.com is no longer there and hasport didnt really give me any info which is weird b/c a few months ago they had tons... Maybe I just need to look a little harder...
So another question is the car that the b20 is going in is an automagic... We want to swap in a manual... I have a cable tranny already bolted up to the b20 so how hard would it be to switch from hydro to cable or is that just something not worth doing?
****EDIT**** nevermind... just found out hasport has a mount kit to do cable to hydro
Anyone else have any insight? I'd appreciate it!!
TIA again!
Dev
TIA again!
Dev
