B20 questions need help.
Alright i got a b20b4 block and a p75 head. Well my question is can i use my gsr dizzy for that head and can i also use my gsr timing belt.?? I just dropped a vavle in my gsr so the head is no good and my block is still good just need to replace one piston and get the block bored over .50 cuz of dings. But i need a car and i got this b20 block laying around... Ohh yea and can i use a b16 intake manifold and a gsr tb with gsr wiring harness????
Re: B20 questions need help. (GSR_hatch936)
1.) yes you can use an vtec dizzy on a ls head. only 1 bolt out of the three will line up so you will leak some oil.
2.) not sure about the wiring harness but i know that all it would be is making wires longer so thats not a big deal
Re: B20 questions need help. (gshatch)
Hrmm... If i get a Obd0 ls intake and put my gsr tb would tha work..? I got a obd1 harness and obd1 gsr...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR_hatch936 »</TD></TR><TR><TD CLASS="quote">Hrmm... If i get a Obd0 ls intake and put my gsr tb would tha work..? I got a obd1 harness and obd1 gsr...</TD></TR></TABLE>
Need some help guys.
FYI it is not a good idea to only replace 1 piston. You will need to have the block honed, and in order for them to do that you will need to disassemble the entire block. Seeing is how the block will be completely bare, your best bet would be to replace all 4 pistons and rings.
Now would be a good time to start a build if that's what you had ever planned on doing to begin with. However, if you are on a budget, I would recommend looking for another short block. You can find them all over the marketplace and I'm pretty sure someone has one laying around in your area. The cost of pistons and machine work alone will exceed the price of a new/ used block you might find elsewhere.
Re: B20 questions need help. (skunk2chris)
I know what i need to do for my gsr..... I need help on my b20 question..... I got a obd1 gsr which means i can use that harness for my b20..???? that imma put in my car while im rebuilding my gsr block. And i need some info on this about the harness, intake manifold, TB and others.
Use the GSR harness, it should work. You'll have unused connectors tho, like for vtec, and knock, iab, etc..
All intake B16, LS, and Type R intake manifolds interchange. The GSR has a different bolt pattern.
The GSR throttle body will bolt to a B16, LS, Type R, D series intake manifold.
Just make sure you use a new and the correct gasket for the throttle body.
Re: B20 questions need help. (lsvx92eg)
Ok imma just use LS timing belt. Forgot i had it and found it in my storage. :D Thanks H-T for the help! :D
Hrmm i did some research on the b16 intake manifold... I dont think it will work cuz of where the coolant goes through. I think it will bolt up but it will need to be ported to fit the ls head??? Any one know bout this??
Re: B20 questions need help. (fmrprojects)
Hrmm.. Yea ive read it can work but i really dont know how to make it work i guess imma have to go outside and look at it and really see if it does or doesnt.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR_hatch936 »</TD></TR><TR><TD CLASS="quote">Ohh yea and can i use a b16 intake manifold and a gsr tb with gsr wiring harness????</TD></TR></TABLE>
b16 intake manifold won't fit an ls head without modifications where it bolts up to the head. all honda b-series tb's are interchangeable. the wiring harness will work fine as long as it is the same obd series, you'll just leave the 2 vtec plugs, knock sensor, and iab unhooked.
Re: B20 questions need help. (boostedwes)
Alright i got a Ls intake manifold aslo but its obd0.... will that workin ok in a obd1 car?? just if i change the tb and iacv??
it will work you'll just have to play with the vacuum lines since the nipples are in different locations on the obd0s and obd1s.
*****!! My Gsr dizzy doesnt fit... The bolt patterns are different for the ls... Anyone gots a Obd1 LS dizzy they wanna gib?? :D
hatchguy
10-26-2004 04:55 PM
