b20 has no oil squirters, b16 does?
hey i am building a b20vtec with left over b16 head and parts. i pretty much have two complete motors.
as far as i can see, the b20 has no oil squirters in the block and the b16 does have oil squirters. is this gonna be a problem? if so....
should i....
-find a way to tap the b20 block for oil squirters? (i don't want to take crank all apart at this point)
-ignore the oil squirters from the b16 and do without? (is this alright to do and what bad might come of it?)
thanks so much guys!
should i....
Re: b20 has no oil squirters, b16 does?
nah your good. the oil squirters are for just cooling the pistons skirts at high RPMs and the B20/LS crank wont clear the oil squirters people plug and remove them all the time when they stroke gsr or b16 blocks.
gotta listen to larry he is the man not only do they get oil everywhere they also lower your oil pressure, so when you plug them it bumps up your oil pressure
thanks much guys, i will listen to hondatech and to larry. he appears to be the man, whoever he is. he has a very authoritative look in his eye(s).
Resident Gearhead
Check him out.
He is famous for squeezing 300 hp out of 2.0L B-series motors. That's
150 hp per liter!
You should see his results with the K-series...
