b18c5 help
b18c5 help
I'm a noob to hondas but, when u swap a 99 itr engine into a 92 civic how do you transfer it 2 obd1 or 2. I heard that the axle is a problem 2 I searched but couldn't find ne info could sum1 point out how 2 solve this?
Re: b18c5 help (wilsel)
Re: b18c5 help (Can you say Hemi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Can you say Hemi »</TD></TR><TR><TD CLASS="quote">I'm a noob to hondas but, when u swap a 99 itr engine into a 92 civic how do you transfer it 2 obd1 or 2. I heard that the axle is a problem 2 I searched but couldn't find ne info could sum1 point out how 2 solve this?</TD></TR></TABLE>
the engine will bolt right in your 92 civic. the engine is a obd2 so i would recommend using a usdm 0bd2 gsr-itr harness..it will plug right up. the 99 jdm itr motor will come with the larger spline axles 36mm unless you have 98 spec jdm 5 lug on your car those axles will not work...so just get some 94-01 integra axles and they will bolt right up. let me know if you need any other info..good luck
gotboosthatch
05-29-2008 12:19 PM
blackcrx16
03-07-2007 08:01 AM
r0cket247
04-24-2004 04:03 PM
