b18c1 vtec solenoid question
Old 03-25-2008, 07:05 AM
Banned
stevew84's Avatar
Default b18c1 vtec solenoid question
i have a 97 ek with b18c lsvtec in it but the solenoid is not hooked up!! i was curious if someone has any pix showing how it is wired.
thanks
Old 03-25-2008, 07:10 AM
aznej2's Avatar
Default Re: b18c1 vtec solenoid question (stevew84)
http://jdmcity.com/thread36.html that what ur looking for?
Old 03-25-2008, 07:19 AM
Banned
stevew84's Avatar
Default Re: b18c1 vtec solenoid question (aznej2)
i need that also but what im asking now is from the solenoid itself, sitting next to the valve cover, its got two wires coming from it and i guess they just go to the ecu?
Old 03-25-2008, 07:23 AM
aznej2's Avatar
the vtec solenoid itself has 1 wire.. yellow/green goes to ecu pin a4 the vtec oil pressure has two wires one is a ground which u can connect to ur chassis the other goes to d6 im sorry i forgot the colors of the wires on the oil pressure, i believe one is light blue if so this is the one that goes to ur ecu
Modified by aznej2 at 8:33 AM 3/25/2008
Old 03-25-2008, 07:43 AM
Banned
stevew84's Avatar
ok later on tonite i'll take pics of it, everything is modified since its the b18 and b20 bottom. ss oil lines for vtec were ran also. ecu is stock 97 ek with conversion harness so will that throw me off? the correct ecu for this motor is p72 but that is not what i have. i gotta take a look at the serial number again but i know its a stock obd2 ecu for 97 civic
CivicxTree754
04-27-2011 11:51 AM
sedrohatchstyle
12-15-2007 08:11 AM
EGB18C
02-02-2006 02:57 PM
yellowjdmcrx
12-12-2005 04:15 PM
DJ_SaNdOz
21
01-19-2005 07:49 AM
Quick Reply: b18c1 vtec solenoid question
